Tamiya TT02 Thread
#2821
For a box stock set up (friction shocks and all) I would say to switch because of the wheel base first making the biggest change. Any Tamiya body with a rear wing is also going to help a ton. The Raikiri is the best imo. The BRZ GT300, Ferrari 458, GTR, STI are all very decent or a 04 NSX lid if you can get ahold of one. Use a set of 26mm wheels as well, all the way around and see how it goes.
So If set up correctly, it will surprise you.
#2822
If your track allows it, pick up some yeah racing shocks. if it has to be Tamiya pick up the plastic CVA or if you can spend a little more the TRF shocks. Either way, you need oil filled shocks
#2823
My suggestions were mainly based on box stock no options. I hear you though! The tt02’s are so capable with a good pair of hands.
#2824
Next would be slicks that come with the Porsche kit. I bet you they are using left over stock from TA01 days in the 90s. The rubber on them is junk.
The released the Super Grip radials on 30mm, pair those with the front 26 mm and it will change the car dramatically.
https://www.tamiyausa.com/shop/tires...-radial-tires/
#2825
Hi all,
Thanks for all the info!
Nothing as far as im aware, me neither.
I agree, 80% is tyres. i just hadn't realised they'd be using different tyre compounds/rubber in the TT line up
I actually like the way it looks bouncing around, look more realistic to me
They do allow it, ive ordered some Tamiya CVAs.
i have been running this car for years now and normally finish top 3. I just thought everyone had the same traction issue, as they always complain of lack of grip.I
I've just learnt to drive it like a proper 911, just annoying when i get it wrong and spin out.
These are the ones i have -Tamiya 50547 (SP547) Wide Racing Slick Tires w/inner Sponge (1 Pair).
I've ordered some Tamiya CVAs, do you mean reduce the rear droop to stop front weight transfer?
I'll try a set of the Super grips if this doesn't work. Edit - Seems the Super Grips are out of stock everywhere!
For those interested in how much wear you can get out of these, i ran the kit tyres for 3 years - Outdoor asphalt (32s lap), we have a large, low grip surface
By this stage it was basically on the carcass, and noticeably affected the top speed/rollout
Thanks I missed that. Ok well there is your issue right there, you can’t race a car with oil filled shocks using the pogo sticks lol.
Those Pogo stix gotta go though lol.
#2826
If your group allows different tires there are obviously a lot of choice. In the Tamiya Championship Series in the U.S. they allow the Tamiya type"A," Type "B," and Type "C" in the GT Pro Spec Class and any Tamiya 24mm or 26mm rubber tire in the GT Spec Novice Class. Obviously, there are a lot of good tires out there. But, if you are restricted to kit tires none of that matters.
#2828
Ola!
Got myself a TT02 Subaru '99 a few months back, and I think time has now come to build it.
An aluminum main drive shaft and and a set of ball bearings are the only upgrades so far. Bearing in mind I do not want to spend a ridiculous amount money on this car, what other valuable upgrade would you recommend?
To add some spice to it all, what sort of brushless combo would you recommend, together with what pinion and spur?
TYA in advance!
TYA in advance!
#2830
Do I understand correctly the manual, a 29T pinion requires a different motor mount?
As far as shocks go, 55mm will do, or otherwise?
#2831
No need for a different motor mount to use a 29t pinion. Only items you need to have is Tamiya 54500 TT-02 high speed gear set and 64 t spur gear (Tamiya 51356). 54500 manual gives you an overview which final drive ratios can be achieved.
55mmm shocks are fine, different options are available, Tamiya CVA plastic dampers 54753, or Tamiya 42102 TRF aluminum shocks, or Yeah Racing ones.
#2833
13.5T is generally a good match to Tamiya chassis too and the kit ESC shoukd run it fine. No need for the latest and greatest either, a cheap Trackstar motir would be fine, or look at the Surpass range, basically older ones are cheaper, later are better but more expensive, all work well
#2834
If you get the high speed gearset then you can run any gears and aren't limited to Tamiya ones. Look at the Yeah Racing motor mount too, it has a slot instead of the set holes so you can set the gearmesh. This means you can run any combination of gears. I would switch to 48p while you're at it, they are just a lot easier to get than the mod .6
Thinking about this combo, in 4000Kv
https://www.hobbywing.com/goods.php?id=579
Will this motor work to its full potential on stock ESC (manual is quite vague on compatibilities)?
TYA!
#2835
Thank you all.
TYA!
TYA!
I don't have any sensorless systems so i don't know how bad the cogging would be at low speed. 4000kv is plenty though if you buy the combo with ESC, it should be fast enough
1387Likes
