Tamiya TA05 Touring Sedan
#9391
question again
is it adviceable to use front oneway in TA-05?
if so, what should i get to change my setup to oneway (parts name and code#)?
im using stock setup of TA05r and i want ro use oneway
#9393
High traction prepared track or carpet, it would work but is ususally used in mod not stock.
Loose traction parking lot, No. Some people like to use a spool in front on parking lots (it give good braking on loose surfaces).
Braking will only be on the rear wheels since the fronts will freewheel.
There are several manufacturers that make a one-way for the TA05; Tamiya, 3Racing, TopCad, Yeah and more. So just tell your LHS which one you want and be sure that the 36T pulley (wide spaced or regular) comes with it.
#9394
Registered User
this is what i did to my ta-05 drift machine
not willing to sacrifice and cut off my servo ear, i cut off the chassis!!.
no problems till now..
and for my new esc, since its too big.. i cut off the chassis too!!!
note the bottom right corner so close to the belt
#9395
What is the advantage of using the rear Evo hubs apart from durability? I read that one could use the "3rd happy hole"?
#9396
If you are going to get the TA05 one way you will also need to get a 37T pulley to keep the same drive train ratio. The TA05 has a 36T pulley, while the TA05R has a 37T pulley. The TA05R drive train is adopted from the TRF416, thus the larger pulley. The one way will have a 36T pulley incldued with it, don't use it. If you plan to use the TA05 front one way make sure that you get part no#54023 37T one way pulley. The package for the pulley will say that it is for the DB01, but it is also useable with TRF501X & TRF416.
#9397
http://www.tamiyausa.com/product/ite...oduct-id=49418
http://www.tamiyausa.com/search.php?....x=0&image.y=0
It is the 05IFSR that is using the 37T
http://www.tamiyausa.com/product/ite...oduct-id=49491
#9398
Has anyone had any problems with the static as mentioned in the manual with metal gear servos?
#9399
Did you get a 37T pulley with yours?
#9403
Thanks, So basically i want be able to run like the mazda 6 bodies on a IFS? just trying to get the feel of on-road ya know. sorry for all the stupid questions but seems like no one around here either wants to answer them or actually know what the heck there talking about. so in other words, there is basically no difference other than running different bodies?
#9405
