Tamiya TA05 Touring Sedan
#5626
Originally Posted by Grizzbob
Very cool, thanks guys, that clears things up a bit, & pretty much fits what I was planning to do anyway(my tendency is to get used to a car first before I make any significant changes to it, but I still like to get the lowdown on the stuff I keep hearing about along the way), for now I think the most I'll change is puting universals on it & maybe playing with toe settings a bit(once I can get the blocks, Speed Tech's out of stock right now)....
hey Bob... if you want to experiment until they get back in stock, i usually have a good selection of them with me you could try out and test.
wes
#5627
Regional Moderator
Originally Posted by scotwithonly1t
I have a general Tamiya question: Why do Tamiya springs run so soft? It seems the stiffer springs in the Tamiya line up often compare to the medium springs of other brands. Just curious. Thanks in advance.
But at the same time CIVIC was running Associated coppers I think, which are stiffer than the stiffest Tamiya springs, and he was TQ.
So it may just be about driving style.
#5629
Originally Posted by CRASH
Purple 22.72
Grey 20.91
White Short 17.54
Silver 16.13
Blue Short 15.69
White 15.27
Blue 14.08
Yellow Short 13.99
Yellow 13.33
Red Short 12.35
Red 11.86
Blue ProMod 8.5 Not tested
Yellow ProMod 7.5 Not tested
Red ProMod 6.5 6.42
These are the actual pounds as tested by TryHard
Hope that helps,
Grey 20.91
White Short 17.54
Silver 16.13
Blue Short 15.69
White 15.27
Blue 14.08
Yellow Short 13.99
Yellow 13.33
Red Short 12.35
Red 11.86
Red ProMod 6.5 6.42
Hope that helps,
#5630
Originally Posted by YAH
Are the yellow springs that come with the TRF damper set the same as the ones in the On-road Tuned Hard Springs set?
#5633
Regional Moderator
#5634
Well, heres a copy of my latest setup for carpet/foam. This setup should work really well with 19 or stock. You may notice the neg. 3 deg. camber...believe me, it seems like a lot, but this car needs that much to not cone the tires, and it doesn't hinder the setup at all. Let me know if you guys have ???s
#5636
Originally Posted by Darkseid
As the chart shows, there is a mild poundage difference, but the biggest difference is that the TRF damper yellows are tall and the Tuned Spring set Yellows are short.
The short yellow springs are part #53631, "On Road Short Spring Set", and were included in some kits - my TA04-R Tuned chassis kit being one example.
HTH
