Tamiya TA05 Touring Sedan
#4772
do the 48 mm shafts work on the normal suspension or are they to long?
#4774
I have a LRP Neo one brushless in my TA05 with an Orion LIPO and Im wondering about what size pinion to put on it? Im not racing it just playing in the parking lot with it. Anyone with ideas or experiance with this? Thanks!!!
#4775
Center shaft one-way
Need a little help here....I picked up a center shaft one-way without directions can somebody please help before I pull out the rest of my hair.
I have all parts just need help in the order (2)paper shims (1)large anodized
washer plus (3) small shims.
Thanks in advance -Mike-
#4778
Originally Posted by Turbonium
just had mine apart yesterday... it goes:
spur holder
alum washer
papery washer
oneway pulley
papery washer
small shims
bearing
i think the small shims may need to be checked, as they are to reduce s-side clearance. i think my car only required 2....
Wes
spur holder
alum washer
papery washer
oneway pulley
papery washer
small shims
bearing
Wes
And why did you have yours apart Mister???!!! LMAO!! Thanks for the loaner!
Brant
#4779
spur holder
alum washer
papery washer
oneway pulley
papery washer
small shims
bearing
Wes
spur holder
alum washer
papery washer
oneway pulley
papery washer
small shims
bearing
Wes
clip
Bearing
spur gear holder
plastic pulley
busging paper spacer
one way pulley
paper spacer
1mm metal spacer
shim
shim
bearing
clip
#4780
Annoying C-Clips
Originally Posted by tamiyarcracer
The above is wrong
clip
Bearing
spur gear holder
plastic pulley
one way pulley
paper spacer
1mm metal spacer
shim
shim
bearing
clip
clip
Bearing
spur gear holder
plastic pulley
one way pulley
paper spacer
1mm metal spacer
shim
shim
bearing
clip
you can also just run one. (i kept my one c-clip on the spur gear side). makes it easier/faster to switch from locked center to oneway.
#4781
The light weight version of the shaft does not even have the grooves for the C clips. So you really don't need them.
#4783
Originally Posted by A-Ko
I have been C clip free since mid April, agree you don't need them.
Although for those that like putting them on and off keep using them. . .
#4784
Hi,
Hebiki,
How's the EVO 5????? I'm still drooling over those pics. the only downside looks to be changing the spur gear.
do you know if the TRF (I think that's what it's called) Tamiya Motor mount for the TA-05 is available yet????.
I'm makinig another list of things to order and thought I'd add that to it if I could get it. and one last Q. have you tried the spektrum stuff for the Heilos yet??? (Pro series)
Thanks.
and is anyone else having trouble veiwing the attachments
here???? we got hit by and virus like WinFixer and we're still trying to sort out all our computers. so far I can post but I can't see any avartars or thumnails posted in threads.
so wacth out for something that will show up as eurogambling in your task bar. then turn into adultfriend finder.com after you delete the eurogambling.
Hope all of you miss this one
Hebiki,
Thanks.
#4785
Yup Chris...that's a tenth right there!
I won't be down there for this weekend's TCS. Good luck man, I'm rooting for ya. Take home GT2 and GT3.
