Tamiya TA05 Touring Sedan
#2642
I had a pair installed on the front. It seems to work fine, just had to remove the red foam spacers. Haven't tried it on the rears though.
Part# used: 53871
Part# used: 53871
Originally Posted by cheehtae
will a 48mm swing shaft fit on a regular non light weight suspension?
#2643
I was at Steve's yesterday and saw the XR-05 he is working on in his case. As far as the way it looks you would never guess it was not Tamiya's flagship. Although i would be getting the car for TCS so i can put all the really cool stuff on it!
#2644
Originally Posted by jas
Hello,
Anyone has a list of the part numbers of the usual spare parts (arms, hubs, etc) that one should stock up for the TA05? I've read that the TA05 shares some suspension parts with other Tamiya touring cars, but really don't know exactly which ones are also for the TA05. Btw, I'm not looking for the upgrade parts like the Lightweight susp. kit, just the normal usual replacement parts. Thanks in advance!
http://cgi.ebay.com/TAMIYA-1-10-R-C-...QQcmdZViewItem
#2645
Originally Posted by ZacMan777
I'm new to the hobby. My TA05 runs well for me, but I have a continual problem with turn buckles falling off. If I just bump the burm or another car, I'm often down.
I've tried low friction, titatium, replacing all again and again. But nothing has worked. Does anyone have any tips for making my turn buckles more resiliant to my lower driving skills?
#2646
Originally Posted by Teehomo
ZacMan777 I've had the same problem - in one case I even knocked a steering turnbuckle set off completely and had to look for it on the track. Is there an aftermarket tie rod end that has a tighter fit or perhaps another brand?
sorry i can't explain it properly, hope you can understand...
well... pictures worth thousand words.....
#2648
When you guys say "turnbuckle falling off" I'm assuming they are popping off the ball studs? If so, you might want to look into replacing the kit black nylon ball cups with the low friction ones. The materials are different, and the low friction ones are stiffer than the stock nylon black ones as well. Also, while replacing the ball ends, you might want to look into the FL coated ball studs. The stock ones are steel I believe, and for about $6 you can save a lot of weight, gain even smoother suspension movement with the FL coated ball studs. Personally, I only popped off the turnbuckle on the steering a couple of times, and one of them is when I slammed full speed into the driverstand at Tamiya (it was one of them layout with a chicane right before you get on the straight . And yes, it was one of those that was felt by everyone on the driverstand )
Steve Wang
#2649
Originally Posted by SpeedTech
Hi guys,
Steve Wang
Steve Wang
the trick i posted was from last time when i used a kyosho tf-2 and it popped out most of the time so i just had to do that.
#2650
Hi guys,
Steve Wang
Steve Wang
#2651
anyone can tell me how to remove the small clip that secures the center pulley assembly?
#2652
hammer well i used two small screw drivers at each end of the clip and the clip pops off, but careful becasue if you flick the clip off and you cant find after it will be a real b*****d to find it on the floor
ash
ash
#2653
ash
ash
#2654
because when i did mine the clip came off but flung off onto the carpet i never found the blimin thing
#2655
Hi guys,
Steve Wang
Steve Wang
