EDAM E-Spirit 220 mm
#61
Lehner 1930 series are 550 size i think but they are really very expensive.
#62
NDZ, Lehner motor is some kind of 550 size bruhless motor?, I think 11.1V + 550 sized motors are the key with this car. I broke 4.5T 540 rotor last week in 2S config. You said you fired your RX8 ESC?. Recommend ratio for 11.1V 3S lipos is <7.5. Which ratio you used?.
Regards
Regards
#63
I broke sintered rotor of my 4.5T with this car, this can also happen with "ordinary" 190 mm touring electric cars but I think this car needs 3S 11.1V and a 4 pole short course motor 540/550 to work properly on big asphalt tracks because of its extra-weight (Short course electronics for onroad car!!) Edam makes 5 mm axle pinions for this car, so i think this is the solution.
If you see Serpent 747e and Mugen MTX5 ECO prototypes all of them use 1/8 ESC (Tekin RX8/LRP iX8) and 4 poles 540 for 200 mm, for 220 i think 550 with 5 mm axle is the right way to go.
Expensive electronics but even cheaper than a nitro engine.
#64
NDZ, I am going to use Espirit with this combo:
HobbyWing Combo SCT-PRO-A Xerun-SCT Pro esc + 3672 Motor
[HW-COMBO-SCT-PRO-A]
ESC is 120A-760A 2S-4S lipos
Motor is 4000 kv 550 size and 5 mm axle
Final rpm about 50400 rpm with 3S, not too much but enough if electronics works without melting or firing components...
#65
Searching on youtube i found this video, they are not ESpirits 220 GPRs but Kyoshos 1/10 nitro converted to electric using 4S lipos electronics, Lola bodies and GPR superbarchetta foams . Same concept:
+ YouTube Video | |
#66
#67
What kind of electronic was used (esc, motor and batteries)?
#68
ESC: 1/8 Toro 150A
Motor: Turnigy Trackstar 5600 kv 4 poles 5 mm axle
Lipo: LRP 4500 mah 11.1V
Gear ratio: 86/23
Gear ratio: 86/23
#69
#70
About 6-8 minutes in 220 Lola config. You can find more info from the french drivers at this link:
http://www.rcmag.com/modules.php?nam...topic&p=794465
#71
Does anyone make rubber tires for 220mm set ups???
