Xray T4 '13
Old 06-02-2013, 09:10 AM
  #3916
edhchoe's Avatar
Trader Rating: 41 (100%+)
Add more droop to the rear. The car will be able to transfer more weight to the front when slowing down.
edhchoe is offline
Old 06-02-2013, 09:18 AM
  #3917
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by rack View Post
So have anybody found that the car pushing on entry. I tried 2.7's springs all the way around that did not help much. I am running the basic asphalt set for now. I need to know the fix for this.
There are a heap of things you can do: stand up front shocks, less rear toe in, shorten front camber link, softer front swaybar, lighter rear diff oil..etc.
defcone is offline
Old 06-02-2013, 09:25 AM
  #3918
TT_Vert's Avatar
Trader Rating: 72 (100%+)
[QUOTEsdefcone;12215226]There are a heap of things you can do: stand up front shocks, less rear toe in, shorten front camber link, softer front swaybar, lighter rear diff oil..etc.[/QUOTE]
Won't standing up the front shocks stiffen the front end?
TT_Vert is offline
Old 06-02-2013, 09:41 AM
  #3919
rack's Avatar
Trader Rating: 68 (100%+)
thanks for the help
rack is offline
Old 06-02-2013, 10:00 AM
  #3920
chasingthepack's Avatar
Won't standing up the front shocks stiffen the front end?[/QUOTE]yes but as the weight transfers to the front it pushes the tyres into the surface harder,i would stand up the shocks 1 hole and drop the rear droop by a 1/2
chasingthepack is offline
Old 06-02-2013, 12:59 PM
  #3921
This worked best for me and gave me more steering.
JOE SI is offline
Old 06-02-2013, 02:46 PM
  #3922
TT_Vert's Avatar
This worked best for me and gave me more steering.[/QUOTE]
So conversely, stiffening the rear end will help on power rear traction? I just don't get this as there just isn't as much weight allowed to transfer.
Dave
TT_Vert is offline
Old 06-02-2013, 05:02 PM
  #3923
IMO stiffening the front will make the front dive less but since the shocks will be a little stiffer push down on the tires more giving more steering and grip
JOE SI is offline
Old 06-02-2013, 07:20 PM
  #3924
erchn's Avatar
I'm going to state a non-answer, but IMO it's true. Nothing in car setup is an absolute.
When someone says, "I need more steering", that can mean quite a few things. Stiffening the front-end as JOE and defcone have recommended can certainly help certain types of steering. In particular initial steering will be improved, making the car feel more "direct". It can hamper other portions of the steering equation, but since the original request was to get into the corner faster it can help. It's also true that with a softer spring you'll transition weight more quickly and can get you to mid-corner faster which will let the car's roll take effect, generating rotation.
Take a look at Martin Crisp's mobile app, there are many times that it says something along the lines of, "do this, but sometimes do the opposite". It's all relative to the other factors effecting the car, most specifically tires and track conditions.
Some options were certainly presented, and they just might meet your needs. Testing in your specific situation is the right answer. Above all, take notes as to your results, and try no more than 1 or two things at a time, preferably 1, otherwise you'll be unaware of what worked or didn't work.
Good luck.
Ethan
erchn is offline
Old 06-02-2013, 07:21 PM
  #3925
nerdling's Avatar
Hi Guys,
chasing a bit of corner exit stability. The setup is mostly kit with 1k diff oil. I've got nice turn in and don't want to loose any. I'm thinking less front droop will give me what I need.
Thoughts?
nerdling is offline
Old 06-02-2013, 07:32 PM
  #3926
Good luck.
Ethan
I totally agree, the only way is to make a change and test since no one really knows what the rest of the car feels like. Someone else can drive it, love it and say leave it alone.
In my situation, I needed turn in and it worked so I'd recommend to try it
JOE SI is offline
Old 06-02-2013, 09:25 PM
  #3927
Kellen Guthrie's Avatar
Originally Posted by nerdling View Post
Hi Guys,
Thoughts?
Less front droop will keep more weight on the front end and give you more on power steering. Try going the other way. If you have more front droop the front end will pick up off the ground more and more weight will transfer to the rear end.
Kellen Guthrie is offline
Old 06-02-2013, 09:42 PM
  #3928
nerdling's Avatar
Will do...
thx.
nerdling is offline
Old 06-03-2013, 01:15 AM
  #3929
hi all,
i noticed that i have a certain play (say about 1.5mm) in the layshaft, which moves horintoally inside the layshaft bulkheads... but nothing is wrong, the bulkheads have the correct orientation, the bearings are not damaged... so is this ok ? i don't think that so much play is ok, sometimes the 20t pulleys scrub against the bulkheads if the layshaft is all the way to left or right....
i definitly need some advice...thx
fabrc68 is offline
Old 06-03-2013, 02:12 AM
  #3930
Hi Guys,
Thoughts?
try a thicker oil in the diff,go up to 2000cst
