Xray T4 '13
#2852
About 84 mm would be nice
#2853
Handling issue, During racing this week i was experiencing issues and was wondering if anyone could provide suggesitons. Its a small indoor track, on the tight hairpins at the end of the main straight and longer straights i was struggling with the car pushing and having to brake to get the car round so i was loosing lots of corenering speed. But then in the sweeping corners it would also push if to fast but then if i let off power the car would come round on me. info XRAY T4 350 oil front and 450 back, 2.7 F 2.5 R springs, 1.5 camber all round, 1 deg toe out on front. Highish roll centre set up i.e medium length links front and short rear with 1 hole hubs. 2mm inner and 1mm outer spacer on links at front. 1mm spacer on inner and 4mm outer at rear. 2000 cst oil in rear diff. 6 downstop front and 4.5 downstop rear
Hope this is enough information
#2854
#2855
thanks
#2859
transfeering the weight to the front will give me more steering though wont it? which is what i am after in the slower turns
#2860
As EA suggested, try 400 ft and 350 rear, i bet this will help your car greatly.
#2861
Team EAM
yes is will. And a heavier rear oil will transfer weight from the rear tires to the front tires slower, meaning you will have to wait longer before you get the weight on the front tires so you have more entry steering.
I think that heavy rear oil is causing your issues.
EA
#2862
#2864
I have also found a 1.3mm rear roll bar quite useful.
#2865
More weight= more traction right?? So more weight on front= more cornering(oversteer) due to relatively lower grip on rear?
So to reduce understeer(push) at the entry of corner, faster weight transfer to front is vital. To achieve that, larger piston holes/more piston holes/thinner oil/soft shock springs, right? Please correct me if I'm wrong.
