Like Tree2Likes
Xray T4 '13
Old 02-22-2013, 07:17 AM
  #2821
Chrissy C's Avatar
Originally Posted by Chrissy C
Hi,
If i put the track width spacers shown in the T4 manual (i.e. RR 0.75mm each side front 0mm) on my T3'12 chassis, will the trackwidth be the same...or is the T4 chassis drilled differently?
Does anyone know what the centre of the pin to centre pin measurements are RR and FR on the T4?
And lastly...
Is the trackwidth of the kit T4 the same as the Hagberg mod that a lot of people did on the T3'12?
Cheers guys, i'm just getting myslef confused and need some help lol!
Best,
Chris
I think I've found the answer...
On the XRAY web page for the T4 they say that the RF holders have been moved inboard by 0.75mm each side (very close to Hagberg mod). Using these and some figures from the Exotek XR3'12 page, i THINK that the RR trackwidth (centre of pin to centre of pin) of the T4 is 44.5mm and the RF is 40mm...I would appreciate confirmation if possible though.
Thanks.
Chrissy C is offline
Old 02-22-2013, 07:29 AM
  #2822
Mikkel_R's Avatar
Thanks.
The RR hangers are the same on both cars they use different washers to get the track width.
Mikkel_R is offline
Old 02-22-2013, 07:38 AM
  #2823
Chrissy C's Avatar
Yep, thanks Mikkel, I thought the RR distance was the same, as you say XRAY just reduced the spacer from 1.5mm to 0.75mm per side, but I wasn't sure about the RF - the XRAY website confirmed that the RF has been re-drilled.
Thanks for the replies mate.
Old 02-22-2013, 07:46 AM
  #2824
Skiddins's Avatar
Hi,
And lastly...
Best,
Chris
The rear track width, before any shims etc, is 0.75mm narrower at the pivot block mounts at the front of the rear wishbones.
This is why the T4 uses 0.75mm shims at the rear to get 3deg toe in, while the T3'12 uses 1.5mm to get 3deg toe.
So the T4 is part way towards the 'Hagberg mod' which if I recall, was 1mm narrower.
Skiddins
Skiddins is offline
Old 02-22-2013, 10:04 PM
  #2825
Losiho's Avatar
From Martin Hudy's Twitter page -
"Successfully tested some new Xray T4 prototypes"
Does he mean new parts, or an update to the entire kit ? I was thinking of getting a T4 very soon. Now I might wait a while.
Losiho is offline
Old 02-22-2013, 10:11 PM
  #2826
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Xray doesn't usually do too many drastic mid year changes. They release a new TC around every October, so your choice is buy a T4 now, which is still a great car, or wait 7 months for the T4 '14 or whatever.
Dan is offline
Old 02-22-2013, 10:16 PM
  #2827
NR
NR's Avatar
Trader Rating: 52 (100%+)
It's 2 small additional parts for the car
NR is offline
Old 02-22-2013, 10:18 PM
  #2828
Losiho's Avatar
Thanks Nathan.
Any idea what the parts are ?
Losiho is offline
Old 02-24-2013, 07:06 AM
  #2829
cyba888's Avatar
which motor mounts are you guys using?
Seems like this is the only one that will fit?
http://www.ebay.com/itm/Yeah-Racing-...item4aba57e8e4
cyba888 is offline
  #2830
cyba888's Avatar
oops double post
cyba888 is offline
Old 02-24-2013, 07:34 AM
  #2831
alloyslash's Avatar
Trader Rating: 19 (100%+)
I use the YR Tornado fans, they sound like a vaccum cleaner. I have mine servo taped to the chassis and centershaft bulkhead just behind the motor on my T4
alloyslash is offline
Old 02-24-2013, 08:32 AM
  #2832
erchn's Avatar
R1wurks single 30mm fan mount, it's tiny and works great. I blotted a yr 40mm fan to it, though the fan it comes with seems pretty good. All available through tqrcracing.com.
E
erchn is offline
Old 02-24-2013, 09:06 AM
  #2833
Dan
Dan's Avatar
What are you guys thoughts on pro setups where people are running very light shock oil? (for example in the 250cst range front and back)
Just curious on the feedback. I'm running the stock setup at the moment (350cst) and don't think I like the feel of the rear progressive springs. Does not feel consistent for me. Ordered the 2.5 spring to put in the rear and going to try it out. I know a lot of the setups call for 2.7 all around but I'm worried about twitchiness combined with soft oil.
Dan is offline
Old 02-24-2013, 09:16 AM
  #2834
Jochim_18's Avatar
That's why I stay away from Xray I almost got the new T4 but man changes and new car comes out way too fast I know it's innovation but I think they do release new car in-prematurely.. Not bashing xray just my 0.2 cents..
Jochim_18 is offline
Old 02-24-2013, 09:24 AM
  #2835
cyba888's Avatar
E
Thanks have picture of your fan installed?
cyba888 is offline
