Spec-R R1
#2253
5, 6 or 7mm?
#2254
Honestly all you NEED is aluminum hexes. Swaybars help but not always used.
Tamiya ballcups nice to have and needed for steering. Not so much for camber links.
The steerig isnt too bad you just need to shim it and maybe use some orings. Before i got tamiya ballcups all i had to do was put orings on the balls to take up the slack in it all.
Tamiya is much better but i still have one or teo orings in there to keep the rack from flatig around at neutral.
$150 was my limit for the s1. That included all my spares and the upgrades. More than that and an r1 is a much better place to start. I like my s1 but id use it for parts of an r1 if i was buying all that stuff.
#2255
#2256
the driveshafts I used were 3Racing from Rcmart
rcmart.com/3racing-t301-driveshaft-p-36126.html?cPath=595_1077_442
#2259
The DJC's are only needed if you run a spool. Chatter is a non issue with a gear diff in the front.
#2260
Last question from my side.
Shall I rather take the S1 than the XI Sport?
Parts availability is no problem for both cars.
#2263
I run a 6mm hex with a 1mm spacer to clear the Contact foam tyres that I run here. They rub on the lower control arms. I also run 6+1mm on the rear to keep the track width level
#2264
The must be a slight difference between the R1 & S1 in the front end.
@Italboy, just buy the R1, if you want to run with the more expensive cars then you should be able for a fraction of the cost, (sorry S1 drivers), the R1 is near enough a exact identical car to the X-Ray.
#2265
Some good info here. I have one more question. I'm going to upgrade to R1 alu suspension mounts but have noticed that the part number for the pivot balls to mount the pivot pin into the lower arm is different for the R1 and S1 is different but they look the same on the manual. Does anyone know if the there is a difference ?
