Spec-R R1
Old 01-11-2013, 11:05 AM
  #751
SteveM's Avatar
Trader Rating: 165 (100%+)
Originally Posted by handiman
Just bought a S1 and n the midst of assembling.
Ran a T3 11' prior.
A couple of questions,
1) Anyone has limited travel or rather stiff (vertically)front and rear arms with e standard 50mm shafts and recommended tie rods lengths? If so, what is the recommended remedy?
2) I seem to have problems securely a shock cap tightly on one of my shocks. Anyone has issues? Recommended or suggested remedy?
3) Read that some of u use additional flange bearings 5x8x2.5..improved fit and performance?
4) Recommended to run with some slop in the front and rear arms or fill the gaps with spacers?
Appreciate your inputs.
Thanks.
I had a shock cap split and maybe you're having a similar issue.
I've bought the flanged bearings but haven't used them yet.
I have forward/backeard slop on one front suspension arm more than any other that I cannot explain. I've swaped arms and reset the hinge pin carriers, but still have the same issue.
SteveM is offline
Old 01-11-2013, 04:07 PM
  #752
Luke Hobson's Avatar
The slop in the arms is where the 0.1/0.2/0.3mm shims come in great like I've reccomened in the past.
I tighten all the blocks up, see how much play there is, then full with shims until there is almost none (literally 0.1 play) just enough for it to drop under its own weight and be free, and if its slightly stiff still, with the damper off, give both the front and the back of the arm a few taps with the handle of your 2.0 driver, that'll free it up.
An easy fool proof method to getting the arms right
Luke Hobson is offline
Old 01-12-2013, 04:57 AM
  #753
reichsmarshal24's Avatar
Hey guys, I'm about to get an S1 for our local 17.5 blinky club here in Manila.
What's a good baseline FDR for asphalt. And what spur/pinion combo should I use for it?
reichsmarshal24 is offline
Old 01-12-2013, 09:07 AM
  #754
Trader Rating: 84 (100%+)
Just a heads up the tamiya steel gear set for there gear diff does not work for the r1.
jeff jenkins is offline
Old 01-12-2013, 04:58 PM
  #755
trickd122's Avatar
For most motors 4.0FDR is a good baseline. Keep temps 160 degrees or lower to be safe, and running a fan will allow you to gear lower. Remember bigger track smaller FDR smaller track bigger fdr
trickd122 is offline
Old 01-13-2013, 02:56 AM
  #756
well just got home from a club race and tried all kinds of different things on the car and have come up with my best setup yet . i ended up with a much more consistent easy to drive fast car that i could point and shoot with. very happy with the performance from my main event race . I will have the setup posted hopefully after i wake up later. but a hint is 1.5mm sway bar up front and 1.1mm in the rear. yokom pink and blue springs. 1mm higher roll center on lower arm mounts in the front with 1deg of anti dive. front arms all the way back. 3mm front uptravel and 4mm rear uptravel. holy sheet is it good! i will have a link posted later for a pdf setup sheet for everything i ran.
Old 01-13-2013, 05:03 AM
  #757
HK416's Avatar
Originally Posted by HK416
Should be in my hands by next week, will let you know soon. Should solve the problem of placing the spacers that take a lot of time !
Ok, using the white spur Bush now but you need to file the bushes a bit if not it will bind the bearings a bit otherwise it's all good now.
HK416 is offline
Old 01-13-2013, 04:12 PM
  #758
Link to my setup. http://www.petitrc.com/reglages/spec...le20130112.pdf
Old 01-13-2013, 05:07 PM
  #759
Last edited by SpecRC; 01-13-2013 at 10:12 PM. Reason: Stupid ipad doesnt show workings...zzz
SpecRC is offline
Old 01-13-2013, 05:55 PM
  #760
Fuzzi0n's Avatar
Originally Posted by SpecRC
Jeff the page you uploaded looks blank?
By any chance are you using Firefox? If so, go Options>Applications and change .pdf files to open with acrobat/reader rather than previewing in the browser.
Otherwise just right click, save as then open with adobe reader or whatever application you use to view .pdf files and it'll work fine.
Fuzzi0n is offline
Old 01-13-2013, 07:20 PM
  #761
Will Kawada spur gears fit with the Spec R S1 adaptors? If not, what 64p brands do you guys use?
http://www.rcmart.com/kawada-s6496t-...Path=1293_1308
Thanks.
Old 01-13-2013, 09:43 PM
  #762
toast.'s Avatar
Trader Rating: 14 (100%+)
ive heard good things about Kimbrough spurs
http://www.tqrcracing.com/shop/produ....asp?p_id=1366
toast. is offline
Old 01-14-2013, 02:02 AM
  #763
spencehotbodies's Avatar
Hello guys
Just an up date on the car after a couple of outings. Was at my local club yesterday ( Wlrc ), a small turn out which was a shame, but it was very cold. I have been running lukes indoor set up with only change being Hpi silver springs fitted front and back. All can say is the car was so good in low temp conditions. I was running an old set of sorex 28s.
The next thing I will be trying is a set of t-shocks, should have them fitted before I race again.
spencehotbodies is offline
Old 01-14-2013, 02:29 AM
  #764
Default Setup for TITC 2013
Hi Guys...
I'm finally pull the triger on purchasing this car...
Anyway i'll be using it for this coming TITC Race on february...
I'll be going to play 13.5 open brushless...
So any of you guys have a good setup for the start on this layout...
k4mp4q is offline
Old 01-14-2013, 08:09 AM
  #765
handiman's Avatar
Default Spec-R R1
Thanks.
The Kawada gears fit fine.
handiman is offline
