Spec-R R1
Old 05-27-2013, 06:33 PM
  #1501
Suspended
Originally Posted by EricW
Anyone use the 48 pitch gears that come with the car or has everyone switched to 64 pitch?
Also, looking for gearing option for asphalt with a HobbyWing just stock speedo and a SchuurSpeed 17.5 motor. Track is 80x40
I stuck with 48 pitch, mostly because i have a crap load of pinions and spurs from other cars. I think my current gearing is 75/32 and for the track i race on, i can throw another 7T of pinion on there yet. I am still working up on my gearing as i become more consistent with the car.
As for what you should be running, well, i would look in on the fast guys and see what rollout they are using, and work up to that, keeping a close eye on your temps as you do so.
RogerDaShrubber is offline
Old 05-27-2013, 07:07 PM
  #1502
DEE SPEED's Avatar
Default spur
Does HB spur gear fits the R1 ? any one..
DEE SPEED is offline
Old 05-27-2013, 07:15 PM
  #1503
PitNamedGordie's Avatar
Yes.
PitNamedGordie is offline
Old 05-30-2013, 12:05 PM
  #1504
R/C Tech Elite Member
EricW's Avatar
What size spur comes with the Spec-R S1 kit?
EricW is offline
Old 05-30-2013, 02:18 PM
  #1505
The S1 comes with a 84T 48p spur gear, hope this helps
lazydurka is offline
Old 05-30-2013, 04:28 PM
  #1506
EricW's Avatar
Thank you
EricW is offline
Old 05-30-2013, 06:16 PM
  #1507
rcdave1's Avatar
Trader Rating: 14 (100%+)
Don't mean to jump the thread just wanted to let you guys know i was selling my spec r r1, you can find info at http://www.rctech.net/forum/r-c-item...spec-r-r1.html
rcdave1 is offline
Old 05-31-2013, 09:17 PM
  #1508
smittyusmc's Avatar
So is the only place you can buy parts for this car is there website? Does any place sell parts in the states.
smittyusmc is offline
Old 05-31-2013, 09:20 PM
  #1509
Nope, I get everything from TQ RC Racing.
http://www.tqrcracing.com/
My S1 won the VTA A-main tonight in Indy. I wasn't driving it, but it beat a field of 15 or more.
.crispy is offline
Old 06-01-2013, 08:13 AM
  #1510
smittyusmc's Avatar
Great thanks
Old 06-01-2013, 02:20 PM
  #1511
Reflex Racing out of Texas also carries Spec R R1 and S1 parts:
http://www.reflexracing.net/
JimmyMack12 is offline
Old 06-01-2013, 04:30 PM
  #1512
Finally got some time to work and finish my R1 stock by the manual setup. Running HW justock 10.5T class and nanotech 6000mah, 31T pinion and stock 84T spur looking for ratio 5, it just fits snug one more teeth and couldn't screw the motor. Now it just need to stop raining every weekend so I can get it to the track...
Only need of some shimming in steering rack and spur gear. Thinking of double CVD as next hopup to get out vibration at max turning angle.
Its my first paint job so didn't make fancy stuff and gradients, just followed the body lines and some freehand with the rattle cans...
oi41.tinypic.com/inaefr.jpg[/IMG]
oi41.tinypic.com/2vc8cja.jpg[/IMG]
oi40.tinypic.com/64jg4p.jpg[/IMG]
oi40.tinypic.com/35jwe0x.jpg[/IMG]
pata is offline
Old 06-01-2013, 04:40 PM
  #1513
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Fixed the code for you:
IIGQ4U is offline
Old 06-01-2013, 05:33 PM
  #1514
Potoczak's Avatar
Trader Rating: 120 (100%+)
Hey guys looking for a good starting setup for medium to high bite technical asphalt track. Will be running 17.5. Thanks for any help.
Potoczak is offline
Old 06-01-2013, 05:50 PM
  #1515
Airwave's Avatar
Just a small advice, 4mm of spacers on a servo-saver could make your steering a little bit blurry... imho 2mm should be the max, and 4mm should be used only with aluminum servo horn (without servo saver)
Airwave is offline
