YOKOMO Touring Car BD-7
#7516
Converting BD7 2014/2015 to BD8
Now BD8 uses 40T gear diff, similar to the BD7 2014/2015, hence is it worth to buy the components like upper deck, chassis, motor mount and the central 20T gear , front spool... to convert it to the BD8?
#7518
It depends on the track condition, 14 may not be slow, the long shocks on 14 can help to generate more traction, especially for low traction asphalt track. The long shocks are more easy to setup than the slf shock sometimes.
#7521
B7-SACF/B7-SACR
hello guys.
i have a question regarding those short front/rear arms convertion for bd7 2015 kit.
maybe more kits since i am not familiar with electric tourings.
what is the efect of use that sets?only front or only rear,or alla together.
in which conditions you use them.plus and cons.
thank you in advice.
#7522
Ive just ordered the RTC kit for the '16, Could anyone tell me if it comes with graphite plastics or standard? Cheers
#7523
hello guys.
#7528
If I wanted to put the BD8 40t pulley set on a 2016 would I need the BD8 cam adjusters as well?
#7530
Ok cheers, Ive seen it advertised as a BD7 option on some sites. I think I will leave mine as it is if thats the case
