Yokomo MR4TC-BD
#1321
Do you have this motor web site ?
thanks !
thanks !
Originally posted by Randy Caster
The motors should be shipping to the distributor really soon, you guys should see em in a couple weeks or so
#1323
Team EAM
What material are you going to use for the spool?
EA
#1324
put out 2 pcs ball bearing first .
oneway bearing move to gear side ,
use 1 pc 7x8x0.5 spacer & 2pcs 4x8x3 copper bearing ,
put to right side ( spur gear side ) use gule to fixed .
in spur gear side open a 2.5 hole
& use 3x3 screw to fix center shaft
If not use can take out 3x3 screw will can use center oneway again !
Last i'm next week will have YOK center direct pulley .
Originally posted by Chrissy C
Leo,
Can you walk me through how you fixed your centre pully. Have you had a chance to try it yet?
Cheers
Leo,
Cheers
#1325
Yokomo Dominates At Yatabe
19-04-2005 19:22:00 GMT +1 - Send this to a friend
Team Yokomo dominates the 2005 Super Stock Championships at Yatabe Arena.
Masami Hirosaka TQs and wins the 2005 Super Stock (23T) Championship with the MR-4TC SDW.
Yokomo drivers finishing in the top 10.
1. Masami Hirosaka (SDW)
2. Takashi Katoh (BD)
3. Shinnosuke Adachi (BD)
5. Shinya Kimura (SDW)
6. Ichiro Fukuda (SDW)
9. Naoto Matsukura (SDW)
(taken from www.teamorion.com)
It seems that the top driver of Yokomo is still runing the shaft version car ...
#1327
R/C Tech Elite Member
Originally posted by EAMotorsports
I would say what by using the Corally Blades that it will be out of alumn.... Will test both alumn and steel. But I have never seen a spool using blades wear out weather it was made of alumn or steel. Either anadized blue or hard anadized.
EA
EA
Most important though, how long do you think it will be before it's ready, we gotta practice for Reedy!
#1328
#1330
Hey Ramon, have you had a chance to run the delrin outdrives yet? I got about 15 runs out of them before tossing them.
I think Yokomo may have changed their outdrive material a bit or something. 2 of my buddies are still running the Yokomo outdrives and they show no wear.
#1331
How can contact ?
Thanks!
Thanks!
Sorry, they are still working on the website.
#1332
only have a couple pack on the BD.. hope to get to the track this weekend.
#1333
The Yatabe Arena race was for 23 turn. hat's why Masami chose the shaft drive car in favour of the belt drive.
Masami should be in Germany this weekend for the LRP Masters race. This is a 12 turn limit race on carpet. It will be interesting to see what car he decides to run.
#1335
I think Masami will run a BD there but we will see. I will report on things like this on the LRP Masters thread in the evening.
