Yokomo MR4TC-BD
Old 04-10-2005, 08:56 AM
  #931
Are there any build tips people would advise i do when i build my BD?
Other than the following one:
Prep chassis,
Soak the belts,
Clean the bearings.
Rick Draper is offline
Old 04-10-2005, 09:49 AM
  #932
Matt Howard's Avatar
I ended up not using any of the included spacers for shimming the diff and oneway and there is barely any play side to side at all. Also, there are two small bearings included that no one has seemed to find a home for Other than that the kit goes together like a dream, and it's really easy to work on with the easy access center shaft and diffs
Matt Howard is offline
Old 04-10-2005, 09:51 AM
  #933
pheyhoe's Avatar
they are not by any chnace for the belt tensioner are they??? bigger OD? just a thought
pheyhoe is offline
Old 04-10-2005, 10:10 AM
  #934
they look like they're bearings for the inside of a diff. I already threw them in with the rest of my extra bearings and I don't remember what size they were.
Old 04-10-2005, 10:42 AM
  #935
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally posted by Mr. Shookie
Which the Tamiya or the Square?
Stephen
I'll be there next Sunday for the JBRL.....Look out for the Mirror E-Stratus in Sportsman. Man I am so old I had to paint it mirror so I can actually race.LOL
Thanks for intel.
They have the Tamiya shims.
Also, anyone looking for a BD but cant find em, I saw 1 in stock at SoCal.
Randy Caster is offline
Old 04-10-2005, 10:49 AM
  #936
Got the car on the track yesterday, and with just a couple changes from the kit setup, it had a ton of steering and cornerspeed. I kept making changes throughout the day and the car got gradually worse, so for next week I'll go back to what I know worked and was really easy to drive.
For the SD guys, do you have any tricks to keeping the wear down on the outdrives? I pitted mine really bad within 2 runs, so just wondering if there are any tricks out there.
Old 04-10-2005, 11:00 AM
  #937
pheyhoe's Avatar
I have that problem too..... the plastic is really quite soft... looking for delrin outdrives now.
pheyhoe is offline
Old 04-10-2005, 11:02 AM
  #938
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
when you find them, let us know -JB
JayBee is offline
Old 04-10-2005, 11:03 AM
  #939
Are SD outdrives a direct fit?
Old 04-10-2005, 11:14 AM
  #940
Those extra bearings were a mistake in the packaging process.
pops is offline
Old 04-10-2005, 11:16 AM
  #941
Yeah, you gotta quit running those 6 and 7 turns!
Don't you guys still run 4 minutes in Mod at So Cal.
pops is offline
Old 04-10-2005, 11:17 AM
  #942
I think they were 4x8s
pops is offline
Old 04-10-2005, 11:18 AM
  #943
Same part. SD-501
pops is offline
Old 04-10-2005, 11:23 AM
  #944
We had 2 BDs running mod at Speedworld, one box stock the other with a lowered roll center with 1 deg of kick up and anti-squat. Changed the box stock by adding 1 deg of kick up and went 500 oil in the front, it won the main and beat TQ. This car is awsome.
pops is offline
Old 04-10-2005, 11:25 AM
  #945
Originally posted by pops
Yeah, you gotta quite running those 6 and 7 turns!
No way to keep up without em
