Yokomo MR4TC-BD
#1681
Originally posted by rc-zombies
how far is Disney from Socal... might be down in the area next week... want to check out Socal... haven't been to the track.
#1687
hi,
im thinking about getting the bd, is there anything i should no about it? do people use the standard c hub hole for the hingepin or the lower one? anything else that should no about the car before i buy it? another thing can you use the rear diff in the front?
many thanks
A Gower
many thanks
A Gower
#1691
where can see ?
#1692
does anybody know which aftermarket spur gears fit the BD?
#1695
Steering Slop
Anyone else notice more slop in the steering than when you first built the kit?
The source seems to be at the bearings mounted in the carbon fiber plate that the steering links connect to. I tried removing the shims but of course that completely locked the steering. I'm thinking maybe a thinner shim.
Unless the bearing itself has become more wobbly, I'm not sure how there could be a change since there doesn't seem to be any wear on the blue steering mounts, and the shims don't seem to have any wear???
Any ideas how I can improve this area?
