Yokomo MR4TC-BD
#6530
Originally Posted by aoizip
I saw that in BMI's thread.
So I think BMI will finally release a thick chassis for BD.. WOOHOO!!
OLando.. you got pm.
~Ming
~Ming
#6531
Trader Rating: 102 (100%+)
it's me
That was me
I'm the only knuckle head who would dare run the Yok on carpet
Actually the Yok started to feel rather planted last week....just a little more work on setup and I'll get my laps back in. Time for some new batteries
#6532
dare run a yokomo on carpet!!! Mine works great on carpet
#6533
Originally Posted by Chris Grainger
Hi Martin
I understand what you are saying I think now, The older kits the chassis was a bit softer, in fact almost every carbon chassis varies slightly in thickness and stiffness, for a big race like the worlds, Yokomo will select chassis for the team so they are all the same..
But if you buy a std BD or My Bd or a Masami bd, that was packed at the same time from the same batch of chassis they should be identical and the part number is the same
They officially do 2 chassis, but there are 3 about
BD-002MG, This is a replacement for the BD-002G, same harness but it has the 4 slots at the front removed, and a extra hole at the back for a new side post that has not been released yet.
A Masami BD or std BD packed a while ago will have the older 002G, but any packed recently will have the newer one.The 002g is now not available from Yokomo, but some shops may still have old stock
Then there is the 002GH, this is still 2.5mm thick but a harder wave so a lot stiffer
Hope this clears it all up
Sir, so there are 3 chassis for BD to choose from. Im racing in flowing track around 60meters of length. Traction is low and have to use traction compound. What chassis would you thing best suits asphalt such as ours. thanks for the reply.
#6534
Originally Posted by Barry Baker
Hey Chris,
How are you?
I am trying to talk Steve into sending Duane to the DHI cup for Checkpoint representation in Europe.......
I hope he and myself can go...
Hope to see you there...
Barry
BTW tell Sam I said hello!
How are you?
Barry
Good to hear from you! be great to see you and Duane there, think Duane should go with you to help us all, and Hara will be there.
You can strip off again and let Craig whip you!!
Chris
#6535
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Originally Posted by JasonC
yes they will work ( they come sandard on the BDM)
#6536
#6537
Err No Tanks !!
Square racing for me or even tamiys Ti is very good & so is F-max
#6538
#6539
Originally Posted by olhipster1
That was me
#6540
Have you guys ever noticed anything wrong with the hard driveshafts? I seem to have a pair of rears that the bearings hardly go on. came to take it to pieces and the inside bearing wouldn't budge, then exploded. we had to cook the ring off it was so tight! worse on one than the other. fronts are fine with the same bearings.
