Yokomo MR4TC-BD
#6511
Originally Posted by pballkid21587
Actually there was talk at cleveland that there will be an Easton edition chassie released by BMI.
#6512
I saw that in BMI's thread.
So I think BMI will finally release a thick chassis for BD.. WOOHOO!!
OLando.. you got pm.
~Ming
~Ming
#6513
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
I measure from top of shock to end of plastic shock end
i use 62mm back & front
#6514
does the mr4tcbd kit wat does it come with for a center layshft and front diff. is the center locked and the fron diff is it a diff spool or 1way thanx
#6516
does anycompany make a loked center and a spool
#6518
now is stock at yokomo usa.
New high volume shock bodies
part # ys-4sss-7
new front suspension mounts ( Front rear)
part # sd-300f05 .5 deg
part # sd-300f10 1 deg
part # sd-300f15 1.5 deg
new masami edition esc ( ko compition 2 clone)
part # 1-sc-mc2
new yokomo battery building jig
part # 1-yt-bj
part # ys-4sss-7
part # 1-sc-mc2
part # 1-yt-bj
#6519
Originally Posted by Chris Grainger
Sorry to disagree with you again but! Cutting to insert down or even just using the new shock bodies that have no insert is a good idea, but if you run the shock 65mm long the piston runs to close to the bladder, you want to keep the piston as far from the bladder as possible, you should not run the shocks longer than 63mm
Chris
Chris
i too had this problem, but i had a set of long shock bodies and they seem to work fine for ride height and droop, however i will try the std rear shock tower and shocks. thanks for the info, i've learn a lot these past few days,
have you tried the front toe blocks yets.
#6520
I can't keep up with all the option and alternate parts for the BD.
It would be helpful if Yokomo published a comprehensive upgrade list on their site for the popular cars, and updated it as new parts were developed and or adapted.
Or is it already out there somewhere?
#6521
here`s the team Tamale fan kit
Also the Yokomo Ali blue diff half`s
i will run them as a straight fit as opposed to converting them to take cyclone blades , the Diff oudrives are really thick & it`s a lot of filing to make (widening the slots )
#6522
think it works my car is allways on pace (just let down by driver on the corners)
#6523
Bomber spool
here`s the $20.00 Bomber spool
#6524
Originally Posted by MR JOLLY
i have the .5 one on just helps the car into & mid to out of corner
#6525
Here`s pic Of Chris Grainger @carpetwars looking cool?? no lost really
