Hot Bodies Cyclone
I replace the cyclone tc rear hubs with a pro4 rear hubs which I bought just recently that's why maybe it came from the batch with mis-molding issue.. anyway I will try the fix that you recommend... until I bought an aluminum rear hub.
STLNST... I have yet to run the car I'm still using my old and trusted pro4 here in parking lot racing.. so still have to see if the uneven toe will result in uneven tire wear. Did the uneven toe affect the handling of the car.. say if the other is 3degrees and the other is 2degrees...
Has anybody tried the HPI rear hub 31417 1/R/L with 2* rear pivot block ???
That would still give you 3* rear toe. There is supposed to be some advantage to having 1* at the wheel and 2* at the pivot block but I don't know what that advantage would be for sure ??? I would like to know more about this combination before I try it myself.
Basically when you introduce outboard toe in, it will make the car turn in softer, but rotate a little more mid-exit. When there is no outboard toe, the car will get into the corner really good, and when you get on throttle (usually mid to exit) the car will hook up really good. It will also have really good forward bite to launch off the corner
I like outboard toe when it's a super tight, high traction track like my home track, Seattle Indoor Raceway. But other than that... usually all inboard toe feels better.
-Korey
-Korey
Thank you jag88
That gives me more to think about.
Thank you STLNLST
Some of the Xray guys think the 1*/ 2* thing works for them is why I asked.
I sure agree with you on the ball studs, I used to break them moving stuff around working on my cars setup.
Thank guys
Thank you STLNLST
Thank guys
s anyone tried the losi 10 mm pistons? The #57 is .0430 in and the 1.1 mm are .0433 in. You think if the 1.1 3 hole pistons were used for most of the rubber tire asphalt setups that they would be easyer to get.
Thank you Korey
Thats a great explanation and gives me more to think about.
HB CYCLONE TC Suspension arm back in stock !
I have just been looking at the pics form the Euro's, looks like Volker is running a few different settings, top deck has been split all the way down the centre, with the rear deck seperated. and it also looks like he is running different front driveshafts, look remarkably similar to losi double joints.
Check out the pic on redrc.net coverage
What pic number are you saying that it looks like Volker is using them, as I cant see it.
Cheers Malc
found this on Red rc, apparently give more rear end grip
Malc
Malc
Anyone run the new pro diff with plastic outdrives with mod motors yet? I was told not to run the plastic pro diff with mod motors because they will be destroyed...which doesnt really make sense...I've run TC5 with plastic diff with 4.5 motors and they lasted over 5 runs as long keep the rings on.
I ran my new TC with a 5.5 and the diff outdrives showed no signs of wear after 5 runs.
I tried using the Losi uj driveshafts in the WCE way back in August last year, but the Losi has imperial size bearings, so had to fit the hub carriers to, they did fit and cut out all the chatter, but the steering geometry was wrong as it lost all steering, so never developed it any further, I put a grub screw in both of the holes in the hub, then drilled a hole in between them, but it just felt wrong, shame really, as there was NO chatter on full lock whatsoever, I used to run the JRX-S and Type R and loved the idea of drive-shafts, maybe I will have another go.
Cheers Malc
Cheers Malc
