Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 03-15-2008, 10:02 PM
  #11356
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
What kind of rims are those?
Good luck
BlackedOutREVO is offline
Old 03-15-2008, 10:41 PM
  #11357
STLNLST's Avatar
Trader Rating: 32 (100%+)
Good luck
Xenon. I ran out of black wheel dots so I went out and got black wheels....LOL They make the car look better than the regular white one's. I just hope my driving backs up the smack talk I laid down OH so beautiful on the rcracing thread
STLNLST is offline
Old 03-15-2008, 11:13 PM
  #11358
Does Billy have them? I need some black rims....
Haha, your driving a cyclone! Of course you can!!!!
Old 03-15-2008, 11:18 PM
  #11359
SammyZ's Avatar
Trader Rating: 138 (100%+)
for you guys running LI-PO, what do you do about the weight issue? Just adjust for tweak using the spring pre-load collars?
SammyZ is offline
Old 03-15-2008, 11:40 PM
  #11360
NO
You use led weights! pre load wont do anything.....
Old 03-16-2008, 05:27 AM
  #11361
STLNLST's Avatar
after racing today I'll take pics of my Orion 4800's and show you what I did to them.
STLNLST is offline
Old 03-16-2008, 09:09 AM
  #11362
Does anyone have pics of Andy Moor's cyclone from IIC?
Old 03-16-2008, 09:45 AM
  #11363
SammyZ's Avatar
Ok right now Im using custom made maxamp packs with lead weight sglued to the bottom for a stealth look. Its like a metal chassis plate that nobody can see and it makes the pack weigh 14oz. I just don't like how the carbon sticker i wrapped it in is started to peel back and look ghetto. Thats why I wanted a nice, hard cased, professional carbon lipo pack. But the retards that make them don't put weight in them.
SammyZ is offline
Old 03-16-2008, 11:09 AM
  #11364
CRASH's Avatar
Trader Rating: 26 (100%+)
Anyone have a used Cyclone they would be willing to sell. I am wanting to put one together for rubber tire carpet and asphalt racing.
Thanks,
CRASH is offline
Old 03-16-2008, 01:14 PM
  #11365
FARBES's Avatar
Thanks,
Hows about Cyclone "S"?
FARBES is offline
Old 03-16-2008, 01:15 PM
  #11366
CRASH's Avatar
I have 2 of them. But Thanks.
Later,
CRASH is offline
Old 03-16-2008, 06:32 PM
  #11367
komkit's Avatar
To use an Associated diff screw what part do I need beside the diff screw and T-nut?
How about thrust ball and washer? Can the original one fit associated diff screw?
Beside the part(s) do I need to drill the outdrive to accommodate the 2.5mm associated diff screw since the original screw is (was) 2mm.
I snapped the Moore speed diff screw’s button head right off during break in the diff on the bench. So, I never even had a chance to run the car
komkit is offline
Old 03-16-2008, 06:44 PM
  #11368
SammyZ's Avatar
My car was pushing bad on corner exit with a front ball diff. I run rubber tire on low grip carpet. Well I swapped the ball diff out for a front one-way and WOW the car is awsome! It has soo much off-power steering! nice!
SammyZ is offline
Old 03-16-2008, 06:56 PM
  #11369
STLNLST's Avatar
WOW is all I can say about this car. I was dialed from the very first battery pack. The car was easy to drive and looked to stay preet flat through the high speed section of the track. I'm running the 16tooth pulley and stock belts to stay with the stock internal ratio of 2.4 What's the ratio if I go to the 18 tooth pulley and longer belts??? Is it like 2.1 or something around there? I turned more than a few heads today after the runs I had. Missed tq after making som mistakes in the last lap and a half. I have a few things I'd like to try the next time out and the next time I will have my boy Scotty to help with the testing.
Bring on the fun!!!!!
STLNLST is offline
Old 03-16-2008, 07:48 PM
  #11370
Did you beat the mamba?
FDR is 2.166 with the 18t pulleys
