Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 07-01-2007, 09:25 AM
  #8941
g_mabry's Avatar
Originally Posted by Cyclone Charlie
This could get expensive at $34 a pop. Has anyone tried a solid center pulley, if so what parts did you use? Would you just use the same pulley that they use for the rear?
Use center direct shaft part #70743 and pulley #70725. It is the same pulley as the rear.
g_mabry is offline
Old 07-01-2007, 11:22 AM
  #8942
Cyclone Charlie's Avatar
Thanks, that's what I thought.
Do you use the center one-way if you use a front spool?
Cyclone Charlie is offline
Old 07-01-2007, 11:43 AM
  #8943
most of the situation, people run locked in center when the front is spool. but of-course the center one way is another option.
HB
Hiro
Hi-LowBlow is offline
Old 07-01-2007, 06:19 PM
  #8944
Suspended
RaceAce701's Avatar
Trader Rating: 87 (99%+)
Has anyone had any problems with the center one-way?
Yesterday after running a couple of packs through the car, mine was slipping. I figured that maybe it just needed to be cleaned and re-lubed. I tried to clean it using some alcohol and found that the bearings were falling out and the caging around the bearings was falling apart.
I thought this was kind of odd for it really not being that old, maybe 30 packs run through the car.
there is really no nead for the center one way i found the car worked better with the looked pully
RaceAce701 is offline
Old 07-01-2007, 06:26 PM
  #8945
Isn't using a spool with a one-way center defeating the purpose of the spool? You still can't brake without spinning out most of the time
HB
Hiro
dorick is offline
Old 07-02-2007, 01:04 AM
  #8946
xray racer's Avatar
Trader Rating: 22 (100%+)
Dorick,
From what i've found, if running a front One-way and the car just needs that little bit extra grip in the rear end, using a spool in the front and a center-one way can help give a little more rear grip.
It settles the car down a little.
Hope that helps,
Cheers,
Robbie
xray racer is offline
Old 07-02-2007, 03:19 AM
  #8947
Hi all.. my version 1 dog bone gave way today.. one of them was slightly bent at the end of my run.. oddly enough there was no impact at all. Anyways i called my hobby shops and most of them seem to be out of stock on the dog bones.. most of them only stock tamiya parts, would a trf cvd work on the cyclone? if not how damaging is it to run a bent dog bone on my cyclone? i'm running it with a 5.5r novak. its only very slightly bent, would it hold up for a few more runs? thanks!
dorick is offline
Old 07-02-2007, 07:56 AM
  #8948
Originally Posted by Deves
Anybody running 48 pitch gears on large tracks?
Yes, I do in Holland. How can I help you?
Z
rcpoint is offline
Old 07-02-2007, 01:40 PM
  #8949
Trader Rating: 80 (100%+)
What is the difference between the Hara and Andy Moore Cyclone versions? Does anyone foresee Hot Bodies coming out with a new Cyclone soon?
cpatel529 is offline
Old 07-02-2007, 01:41 PM
  #8950
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
front spool,cvd's ,shock towers
dont see a new cyclone anytime soon
Marcos.J is offline
Old 07-02-2007, 01:44 PM
  #8951
I am trying to debate which TC to get for the summer asphalt/rubber season. The Hara and Andy Moore versions both look nice but I am looking for a used version.
Do you need any other parts/tuning options besides maybe springs and suspension blocks for either of these cars.
Old 07-02-2007, 02:57 PM
  #8952
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Get a v3 spool for sure, and the v2 steel front shafts, that will save alot of heart ache. The stuff marcus mentioned is good to consider too. What I have broke most on my car was the servo saver, and the spindles. The spindles were due to being stupid and putting too long a screw in it.
BillyCaldwell is offline
Old 07-02-2007, 04:01 PM
  #8953
TFR
TFR's Avatar
Anybody using Novak GTB can post some pictures of the install? I'm using Novak GTB, S9550 and Spektrum micro on a black Cyclone. Thanks.
TFR is offline
Old 07-02-2007, 04:26 PM
  #8954
Super Moderator
Marcos.J's Avatar
thats the same electronics that i sued on my cyclones
Marcos.J is offline
Old 07-02-2007, 09:05 PM
  #8955
sk1pp3r's Avatar
I know i'm blind, but where is the receiver? Is it under all those wires?
I have a spektrum too, but run a novak GTS not B. Works good. Do you like that servo?
Thanks!
sk1pp3r is offline
