Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 01-10-2007, 08:04 AM
  #6631
You mean this one:
http://translate.google.com/translat...lr%3D%26sa%3DG
vassago is offline
Old 01-10-2007, 09:50 PM
  #6632
Hey Guys,
I am running a Surikarn edition with foams on a med/high bite track. Could someone please hook me up with a good setup to include a good tire diameter to start with? The faster guys at our track seem to be running Parma cyan ft and magenta rear. Thanks for the help.
jeremymoemorris is offline
Old 01-10-2007, 10:22 PM
  #6633
rc-zombies's Avatar
Originally Posted by vassago
yes that is the one...
for those with leaky shocks...
when you look at the shock assembly process.. Hara does insert a spacer between the bladder and shock cap.
rc-zombies is offline
Old 01-10-2007, 11:11 PM
  #6634
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by jeremymoemorris
Hey Guys,
Daisuke Yoshioka setup from the "SUMMER NATS" is pretty damn good..... You can get it from here;
http://www.hpiracing.co.jp/contents/.../download.html
Normally foam tyres need to be in the range of 54mm to 58mm
2-Bad is offline
Old 01-11-2007, 12:47 AM
  #6635
Trader Rating: 16 (94%+)
it's much easier to sand the top cap down a fraction of a mm, and it means one less shim to worry about when rebuilding your shocks
domo is offline
Old 01-11-2007, 08:01 AM
  #6636
rc-zombies's Avatar
once the shim is in place...it doesn't come out..it's held in place by the treads..
Old 01-11-2007, 08:28 AM
  #6637
pinggoy's Avatar
Trader Rating: 24 (96%+)
is it a special shim?what are the dimensiOns? thnx
pinggoy is offline
Old 01-11-2007, 08:59 AM
  #6638
rc-zombies's Avatar
I'm at work right now..don't know the size off hand...should be same size as the top of the shock body.
any shim that will fit... I only had the silver shims not like the plastic ones Hara used. I placed mine inside the cap on top of the bladder.
Old 01-11-2007, 09:54 AM
  #6639
|<R1Z |>'s Avatar
Originally Posted by Essnowyt
Hello all that run the Cyclone with rubber tires. This past weekend I finished 8th overall at the Novak Race in Stock Rubber tire. Here is my setup for you all to use. The car was much better than 8th. In the first A main i had a battery bar fail. In the final two A mains the driver was the problem. But it was still a fun weekend.
Snowy.
Why the heavier oil in the rear? What are the benefits? Seems to go against logic. Not saying its wrong..... just trying to understand the rationale.
|<R1Z |> is offline
Old 01-11-2007, 10:17 AM
  #6640
Essnowyt's Avatar
I have been running that oil combo for some time now. It slows the rolling reaction in the rear of the car. The steering of the car is softer. In reality it takes away steering. I felt the car was to reactive, so I stiffened the oil. It very easy to get this car to be very aggressive with rubber tires. However, you need to find a balance of aggressive and drivability.
Hopefully Willy will come here and comment on it also. He made the change to the car at the Novak. His impressions would be more direct to the change. Remember I have kept this combo for 4+ months.
Snowy.
Essnowyt is offline
Old 01-11-2007, 10:44 AM
  #6641
pinggoy's Avatar
how about the diff shims would it fit?
pinggoy is offline
Old 01-11-2007, 12:53 PM
  #6642
2-Bad's Avatar
oops..my bad
2-Bad is offline
Old 01-11-2007, 12:54 PM
  #6643
2-Bad's Avatar
Oh, and yes the diff shims is what I used first to fix it before I shorten the Cylinder Upper Shock Caps. I needed two (1 copper & 1 silver shim) on each shock.
2-Bad is offline
Old 01-11-2007, 03:37 PM
  #6644
HVFracingwilly's Avatar
Trader Rating: 17 (100%+)
Thanks Snowy, put me on the spot.
When I made the change it made the biggest diferance comming into the corner, basically kept the wait on the rear tires. Which in turn made the car very easy to drive.
One thing I also noticed and I think it is listed wrong on your setup is the rear link location on the inner bulkheads, they should be in position 4. Both of our cars were STUCK during Novak, so if you are on a high traction track give this setup a whirl you wont be disapointed.
HVFracingwilly is offline
Old 01-11-2007, 03:56 PM
  #6645
Essnowyt's Avatar
Oh dude your right. The rear link location on the inner bulkheads should be position 4!
Snowy.
Essnowyt is offline
