Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 12-11-2009, 06:01 AM
  #17941
ozvena's Avatar
Default Gearing 17.5T motor
I will be using Mamba Max Pro in sensored setup. It has co called "CHEAT MODE". Thanks for the advice, now I know what to expect (everything still in the mail) and how to deal with it.
ozvena is offline
Old 12-11-2009, 07:02 AM
  #17942
karlo511's Avatar
Originally Posted by Hi-LowBlow
Hi all,
We were at the WCRC(West Coast RC) for some practice today. (KO Grand Prix Day1)
Barry Baker with his Cyclone TC was the fastest on the track whole day today!! We have had some discussion and figured out it can be even better tomorrow.
Checkpoint's power /Cyclone TC chassis combo is MAXIMUM FAST!
Looking forward to see the improvement tomorrow.
that's the MAXIMUM BEST!!!
good luck to the hotbodies team! - karl
karlo511 is offline
Old 12-11-2009, 09:22 AM
  #17943
EJ20's Avatar
Hi all,
Best luck for all HB!
EJ20 is offline
Old 12-11-2009, 05:54 PM
  #17944
ShaunMac's Avatar
I wonder how the Checkpoint motors compare to the Duos or Novaks? Especially in the spec winds.
ShaunMac is offline
Old 12-11-2009, 07:45 PM
  #17945
jag88's Avatar
Korey, what is the difference (if any) between running 4 deg castor with 2deg of kick-up in the hinge pins and a 6 deg castor block with no kick-up ?
Thanks.
jag88 is offline
Old 12-11-2009, 10:20 PM
  #17946
Korey Harbke's Avatar
Hmmm that is something I have not tested in a long time. Whenever I run kickup... it helps with steering off power, but kills any on power steering as it promotes weight transfer to the rear of the car when on power.
I would think the 6 deg with flat pins would be a little more balanced. It would just be smooth entering corners, and provide more steering through the middle and exit. With kickup... it makes the car jack weight around more specific to your throttle input.
Maybe someone has some more recent experience with this? If anyone does, please jump in.
-Korey
Korey Harbke is offline
Old 12-11-2009, 11:44 PM
  #17947
ericbeenorcal's Avatar
Default Serpent S-400 Parting Out NEW!!!!
cvd's $30 each
shock towers front n rear $30 each
upper front and rear left n right aluminum bearing caps $25 each
extra thick 3.5mm carbon chassy $100
extra thin 2.5mm carbon chassy $100
front spool w outdrives $60
rear ball diffs w outdrives $50
front n rear belts $20
front left and right bearing blocks $35 each
rear right bearing block $35
rear left bearing block w motor sink $35
front aluminum c hubs $25 each
front steering knuckles $10 each
rear aluminum uprights $30 each
threaded shock system $20 each
front bumper $15
center aluminum pulley system $40
servo saver $20
upper carbon brace w antenna tube n belt bearings $30
front bumper carbon brace "s400" $10
rear upper carbon pulley brace $10
aluminum hexes all 4 $30
sway bars both f n rear $20
all the end turnbuckles and steering linkages w orange anodized rods $30
front body posts $10/ rear posts $10
Futaba BLS 451 New Brushless Servo $90 .12 transit
New PolyMax B6 Lipo Charger(needs 12v acdc power supply) $80
New Orion 5000MaH 7.2V Stick Pack $45
New Orion 3000MaH 7.2V Stick Pack $30
S-400 entire car as a whole also for sale fully built roller new for $500 + shipping
[email protected]
408-771-9993
tnx yaal
ericbeenorcal is offline
Old 12-12-2009, 08:03 AM
  #17948
STLNLST's Avatar
Trader Rating: 32 (100%+)
-Korey
You know I added kick up to your parking lot set up in hopes of getting the feel of having 6 degree caster blocks. My take on it is that the higher blocks angle the the caster blocks back allowing the car to feel it has more steering on power. I figured kick up tries to acheive the same thing with the angling of the caster blocks but has a slightly different feel to it. Do I have this correct? It felt great on the track and the results were there with my laptimes dropping.
STLNLST is offline
Old 12-12-2009, 07:07 PM
  #17949
Yea. It should feel different as you are changing about 3 things when you do the kickup change. You're changing caster, roll center, and kickup. With just the cast blocks change... all you are changing is caster.
It's something I guess I should test a bit sometime soon. I'll let everyone know what I find.
-Korey
Old 12-12-2009, 09:26 PM
  #17950
STLNLST's Avatar
-Korey
Get to testing so that the rest of us "REGULAR" racers have a clue The car was a rocket with kick up Didn't work too well out at Speedworld though
STLNLST is offline
Old 12-12-2009, 09:53 PM
  #17951
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Hi all,
Hiro, will barry be posting his setup? Do you think it will lend itself well to stock 17.5? I know my car can make 20 laps but im having trouble (driver errors i guess) making it there. Fastest lap for me with 17.5 so far is 15.132. Im not sure if its setup or driver but with the same setup I have, ive gone from 15.5 to 15.3 to 15.1 fast lap. Just gotta stay consistent i guess (and i suppose my outdated GTB isn't helping much either at this point).
Syber Serulean is offline
Old 12-13-2009, 01:55 PM
  #17952
Trader Rating: 19 (100%+)
-Korey
I had good results with .5mm of kick up at NorCal. I have not been able to drive in a while but when I get back it is something I want to try again. It smoothed out the entry a little and gave me a little more steering in the middle and off the corner. It helped keep my speed up on the switch backs. I must have "forgot" to tell STLNLST.....LOL This was on the TOP Spec Tire.
Art
Advil is offline
Old 12-13-2009, 05:41 PM
  #17953
EJ20's Avatar
Congrats to Barry at Ko propo Grand Prix.
EJ20 is offline
Old 12-13-2009, 07:16 PM
  #17954
STLNLST's Avatar
Art
Maybe you should have told Romo to run some kick up
STLNLST is offline
Old 12-13-2009, 09:01 PM
  #17955
Trader Rating: 26 (100%+)
sorry if this has been already answered
but will a cyclone-S carbon fiber chassis fit on my Cyclone TC?
thanks
kriiiss is offline
