Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 03-04-2009, 11:58 AM
  #15511
Trader Rating: 32 (100%+)
Originally Posted by STLNLST
Sweet.......I hope that class takes off. Ling told me about it. I'm going to just stick with 13.5 though. The Tamiya gang will be out there sometime soon.
Yeah,I may just build my Pro4 up to be the RCGT car and leave the Cyclone alone.
Originally Posted by DG Designs
Im running 81/57 for a 17.5 in RCGT. so has anyone had any issues with the 2 way?
What brand spur is the 81?
racenut123 is offline
Old 03-04-2009, 12:24 PM
  #15512
ShaunMac's Avatar
What are the rules for this RCGT class?
ShaunMac is offline
Old 03-04-2009, 12:36 PM
  #15513
Trader Rating: 14 (100%+)
Robinson Racing. You can only use 2 screws to hold the spur though.
DG Designs is offline
Old 03-04-2009, 12:48 PM
  #15514
grapejuice's Avatar
Trader Rating: 152 (100%+)
Anyone have experience with run a rear spool, front diff and a center one-way? I mainly use my cyclone for drifting, and I used to have this set up on my Yokomo SD, the center one-way gives the car the "e-brake" effect to initiate or prolong drifts and keeping the front diff helps with on power turning. Just wondering if it works with the cyclone (I figure it will), since my spool will be here soon and haven't tried it yet.
grapejuice is offline
Old 03-04-2009, 01:18 PM
  #15515
This will work for drifting,not for Onroad racing.I had the same setup on my ta05,and I imagine it would work equally as well if not a little better with the cyclone.
Old 03-04-2009, 01:30 PM
  #15516
Trader Rating: 19 (100%+)
You had a TA05? Wow...I never knew that...want to purchase a RDX??? LOL I might have 2 or 4 laying around still....LOL
Advil is offline
Old 03-04-2009, 01:44 PM
  #15517
Still have it.It was Jimmy J's car from TCS Nats a couple years back. Maybe that should be my RCGT car.
Old 03-04-2009, 03:36 PM
  #15518
LOSI123's Avatar
Trader Rating: 63 (100%+)
Anyone had a problem with thier WCE Cyclone Swaybar holders (the bit that clips onto the A-Arm is tight/Binding. I have all original HB Parts and they are not the tc arms.
LOSI123 is offline
Old 03-04-2009, 03:52 PM
  #15519
So does anyone have any input on what to run in he front for asphalt? Diff, one way or spool? Again this is for RCGT.
Old 03-04-2009, 05:07 PM
  #15520
ShaunMac's Avatar
Spool for rubber tires. Asphalt or carpet. Just set it and forget it.
If you decide to go with a spool. The HB Ver. 3 spool is the best spool out there for the Cyclone. It's very durable. And it's much lighter than the newer TC Spool/One-way combo.
ShaunMac is offline
Old 03-04-2009, 05:26 PM
  #15521
ShaunMac's Avatar
You mean the ball cups? If they seem tight you can use a lighter to heat the ball cups then pop them on the arms. This will stretch the ball cups out slightly allowing them to move more freely on the arm mounts.
ShaunMac is offline
Old 03-04-2009, 08:47 PM
  #15522
STLNLST's Avatar
Originally Posted by RC MARKET
TITC 09
What speedo was Hara using at this race???
STLNLST is offline
Old 03-04-2009, 09:01 PM
  #15523
Korey Harbke's Avatar
For some reason I remember seeing a pic that he was running a Nosram. The pic wasnt close up enough to tell if he was running the new Nosram that they ran at worlds, or just the normal one.
-Korey
Korey Harbke is offline
Old 03-04-2009, 09:09 PM
  #15524
Cool. Thanks for the input.
Old 03-04-2009, 09:12 PM
  #15525
Team STPN's Avatar
Still working on that Speedo, when are you going to give up
Team STPN is offline
