View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
U.S. Vintage Trans-Am Racing Part 2
Taken from USVTA web site
http://www.usvintagetransam.com/rule...10-24-2019.pdf
Trans Am Class Rules and Specifications: as of
6-10-2018
Chassis Specification:
Four Wheel Drive touring car chassis only. Any era or brand 4wd chassis is allowed.
***All Cars must be Full Time 4wheel drive no “1-way” diff or pulley system is allowed***
Ride Height Specification:
Minimum ride height is 5mm on Carpet
Weight Specification:
Minimum 1450g in race-ready trim
Battery Specifications:
ROAR approved 7.4v- 7.6v 2 cell LiPo hard cased, 6000mAh MAX limit. 8.40v is maximum
voltage allowed.
All house track rules regarding LiPo usage apply.
Approved ESCs:
ANY ESC that is ROAR approved and using ROAR approved “Blinky” spec software or on this
list
Tire & Wheel Specifications:
The only tires allowed are PROTOform VTA Rear Tires (31mm) - #10139-00 and PROTOform
VTA Front Tires (26mm) - #10140-00, using stock tire inserts provided with tire and any HPI or
Protoform Vintage wheels designed to fit these tires. All other tires and/or part numbers are
illegal.
Wheels and tires designated as "front" must be used as front tires/wheels, "rear" wheels/tires
must used as rears. Five or Eight spoke wheels available in various colors.
0mm offset front wheels and 6mm offset rear wheels are intended for 26mm width fronts and
31mm width rear tires. HPI 8-spoke Vintage wheels from #3805 through #3814, 5-spoke
Vintage wheels from #3815 through #3822 and Vintage stock car wheels from #3854 through
#3860, Vintage Wheel CC Type #33472 and #33473, Vintage Wheel DTP Type #33474 and
#33475 are all legal wheels. Protoform wheels 2766-03, 2766-04, 2765-03, 2765-04 are all
legal wheels.
Grinding of tire tread is NOT permitted. Sanding of mold seam to remove seam is allowed.
Tire traction compounds are at the discretion of the track.
No other altering, changing or softening of the tire is allowed.
Tires may not be belted or changed to prevent "ballooning".
No "double stuffing" of foam inserts allowed—only single stock vintage tire inserts are allowed.
All decisions of the race promoter or track owner are final.
Motor Specifications:
Any ROAR approved 25.5 motor that is on the ROAR list and only 12.3 rotor
Novak SS25.5 Pro brushless motor (pn:3425V) or Ballistic 25.5 (pn:3625V-stator only
pn:S6625) Club (pn:3331) or Boss (pn:3626V) are grandfathered in and also legal
Only physical motor timing advance is allowed, however Ballistic/Boss motors may be
advanced beyond the last line of the timing range sticker.
12.3 mm rotor diameter only (no "tuning" rotors are allowed, only stock Novak rotors allowed).
Using ceramic bearings in the motor makes you a dork. No modifications or optional parts
allowed on motor can, endbell, stator, or rotor other than the Boss #5925 Ballistic 540 Vented
Endbell/Bearing Racing Upgrade Kit (replacement) .
No cooling holes or other changes allowed to motor.
Fans and external clip on heatsinks are allowed, but integral type heatsinks/fans including but
not limited to those that require motor disassembly to mount are illegal.
Race Specification:
- 5 minute qualifiers
- 8 minute mains
- Larger Races IFMAR-type starts are a better option. All smaller “club” heats and mains
should be straight-up starts, with random sorts for each heat if desired. Non random sorts
should shuffle starting order for each heat.
Optional Main Variations:
- 12-20 car A-mains, depending on car counts.
- Invert qualifying order based on random hat pull (top 6-10 cars).
- "LeMans" type starts where all cars are lined up on an angle to the racing line in order.
- Run track in reverse rotation for mains.
- Rolling starts
MOST IMPORTANTLY: If it's not in the rules, and does not encompass the spirit of
slower,
controlled racing with realistic looking cars, consider it illegal. This is called the "Spirit of
VTA" Rule.
The class is based on slower, equal playing field competition with less traction, minimal
aerodynamic aids and mostly older carpet racing technology. The final objective is close, fair,
wheel-to-wheel racing for all.
Body Specifications:
Late '60s to early '70s American pony car Vintage Trans-Am bodies only
Body provided deck lid spoilers allowed (not wings).
For the HPI, Bolink/RJ Speed Mustangs, McAllister Cougar and others which are not
provided with a spoiler:
A lexan spoiler of 16mm total height from trunk deck, and overall chord of 20mm is
allowable.
All other bodies must use the spoiler included with that specific body set.
Built in spoilers may not be enhanced.
No additional skirts or raised/extended wings or air control surfaces allowed unless specified by
these rules. Body must be trimmed at body trim lines.
Front spoiler may be extended into body to provide durability.
Full rear bumper required.
It is highly preferred that bodies are detailed in race type livery in period-correct paint schemes.
Fluorescent colors, wild graphics, chromes and non-period correct paint schemes are frowned
upon. All cars must have a number on the hood, both doors and trunk lid. Wheel covers of any
type are NOT allowed.
Altering the body for the purpose of lightening by sanding, scraping, or any other method is
ILLEGAL. Body minimum weight 95g - any additional weight required for a legal body
must be added to the roof of body
All cars must include a three dimensional driver figure consisting of at least a head and
shoulders.
Driver Figure part numbers (ANY suitable 1/10 driver figure is legal-these are readily available
examples)
HPI
#104815 INNER BODY SET FOR DT-1 TRUCK BODY
Associated
6180 Driver, unpainted, 1:10
McAllister
#423 Stock Interior and Driver
#419 SPRINT CAR DRIVER
Bolink part numbers:
BL2262 '68 Chevrolet Camaro
Also known as RJ Speed Part # BOL2262
BL2263 '65 Ford Mustang
Also known as RJ Speed Part # BOL2263
HPI part numbers:
17510 - 1970 Plymouth AAR 'Cuda
7494 - 1968 Chevrolet Camaro
17531 - 1969 CHEVROLET CAMARO Z28
17508 - 1965 Ford Shelby GT-350
17519 - 1966 Ford Mustang GT
104926 - 1966 FORD MUSTANG GT COUPE BODY
17546 - 1970 Ford Mustang Boss 302 (scale wing ok)
105106 - 1970 DODGE CHALLENGER BODY
McAllister Racing part numbers:
#286- 1969 Mustang body
#295- 1970 Pontiac Firebird Trans Am VTA body- 1/10- 200mm
#304– 1970 CAMARO TRANS AM BODY–1/10th, 200mm, VTA Class
#305– 1968 COUGAR TRANS AM BODY–1/10th, 200mm, VTA Class
#315- AAR CUDA VTA
Parma part numbers:
10143 - 1969 Z28 Camaro
10141 - 1970 Boss Mustang
10113 - 1970 'Cuda
Pegasus Hobbies part numbers:
PGH4001 - 1970 Camaro SS
PGH4002 - 1970 'Cuda
PGH4003 - 1970 Mustang
Protoform part numbers:
#1526 - J71
#1535-30 1971 Pontiac® Firebird Trans Am
#1552-40 1971 Chevrolet Camaro
#1558-40 1968 Ford® Mustang Clear Body
#1562-40 1969 Chevrolet Camaro Z28
6-10-2018
voltage allowed.
Approved ESCs:
list
illegal.
legal wheels.
Race Specification:
- 8 minute mains
- Rolling starts
slower,
VTA" Rule.
allowable.
shoulders.
examples)
HPI
Associated
McAllister
HPI part numbers:
#315- AAR CUDA VTA
Parma part numbers:
10113 - 1970 'Cuda
#1526 - J71
6-10-2018
voltage allowed.
Approved ESCs:
list
illegal.
legal wheels.
Race Specification:
- 8 minute mains
- Rolling starts
slower,
VTA" Rule.
allowable.
shoulders.
examples)
HPI
Associated
McAllister
HPI part numbers:
#315- AAR CUDA VTA
Parma part numbers:
10113 - 1970 'Cuda
#1526 - J71
6-10-2018
voltage allowed.
Approved ESCs:
list
illegal.
legal wheels.
Race Specification:
- 8 minute mains
- Rolling starts
slower,
VTA" Rule.
allowable.
shoulders.
examples)
HPI
Associated
McAllister
HPI part numbers:
#315- AAR CUDA VTA
Parma part numbers:
10113 - 1970 'Cuda
#1526 - J71
Thank you for posting the latest rules update.
I think another question is, who is writing these rules? This is not ROAR. Is it a committee?
R/C Tech Elite Member
Welcome to the home for the newly created Vintage T/A 1/10th scale R/C road racing class, based on 4wd touring cars. The class rules are developed to provide close racing with controlled chassis, battery, motor, tire and body specifications. The goal of the VTA class is to bring back awesome looking cars in a cost controlled racing format where the result is just plain fun. The speed of the specification package brings close and competitive racing for sportsman, intermediate and experienced hobbyist that rewards driver development.
With a decline in all R/C racing in recent years, racing needs a big shot of fun and excitement--and this is the perfect class. Far more reasonable speeds, low costs, realistic and exciting looking bodies, wheels and tires, less traction and wheel-to-wheel action drive this class. It IS the next big thing. It's appealing not only to spectators, but to new and old racers, alike. For a low initial cost, any prospective Trans-Am racer can get a car, a radio and be racing with very little time or effort. And the fact is that racers who have never raced before can be on the same level playing field as everyone else, and really enjoy doing so.
The basic rules were created by energetic and insightful racers in Wisconsin and Illinois, and have proven to be very effective and successful. All rules will evolve and adapt as the class warrants. New participating tracks are encouraged to grow the class and adapt ideas to the class, and share those ideas with the U.S. Vintage Trans-Am Series, yet stay true to the original ideas and rules. Hopefully, we can all make this a great class to grow with, and bring back the fun and entertainment to road racing.
If your track would like to be a general participating track and run the USVTA class and rules, please [email protected] with any questions you may have. We'd love to have you on board.
USVTA Vintage R/C Racing
Thanks for the insight.
1st problem is that hotmail was phased out in 2013. I was going to ask if this group was still active, but since we just saw an update.
At my local track, VTA has become one of the more dominant classes. For the most part Participation is great. We all struggle with the nuances of this class, but body weight seems odd to change. I wonder what the motivation behind the change is.
Simple, to stop the guys that throw one coat of paint half way on the body for high traction tracks and run it like that
Body weight is something that has come into play for other classes in recent years. From what I heard, the development of ultra lite and pro lite bodies has been partially blamed for increasing occurrence of body tuck. The super thin bodies also don't last near as long for those of us that are less than perfect drivers. Some people also would only dust the body with paint to keep it as light as possible, and it doesn't generally make for a great paint job. I haven't run VTA in a year or two, but my cars have been so light that I have to add so much weight that I run out of places to put it all, and that's for standard 1350 TC minimum!
I am more concerned, and frustrated that a rule was instigated that has no real meaning, but is forcing me to change my cars and spend more money. No new bodies have been added to the list in over a year, but now we are going to limit the existing ones? The point of a rule like this should be to take away or an unfair advantage one has over another. We already have a weight limit. It should be up to the driver how they achieve that weight. If I choose and or feel the car responds better, to spend more time putting all my weight at the center of the chassis, then I should be rewarded for doing so.
If the goal is to level the playing field a roll out or gear limit would be much more effective. If this is going to be a real class, it needs to be treated as such. Rules need to rolled out at the beginning of the year and those rules need to hold through the year. If a rule needs to change an announcement should be made and an explanation to the rule should be announced.
but also keep in mind, a lot of this stuff comes from people volunteering their time for the love of the hobby.
And tracks/races have the final say in how this rolls out and when.
That still does not make it right
I hear this sort of thing a lot when it comes to disagreements with VTA rules. I suppose if you race at a small track in the middle of nowhere, and plan to stay there, you can do as you please, when you please, about rules. Those of us that race at tracks that host bigger "sanctioned" races or those of us that attend out of town "sanctioned" races are affected immediately, and it seems, are given zero warning or say in the matter.
I’m not disagreeing or saying no one has a point. Just purely saying there is more than one way to approach something.
