View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
U.S. Vintage Trans-Am Racing Part 2
If you are looking for the Pegasus "Mustang" body, make sure you are searching for Pegasus 70 Mach Jet. There are a couple on eBay right now (9/26/2023) but expect to pay around $50 USD with shipping.
I also believe that the Firebrand Mach Speed is the same body except it comes with more/different decals. Maybe someone can confirm if it is the same, but I couldn't find any for sale online. Here is a link about this body...
https://www.rccaraction.com/firebran...110-road-body/
Hope this information helps.
Thanks this is good info
I hope Florida stay away from the spec 25.5
motor
motor
If the tires are as good as their USGT tires, they will be a very welcome addition especially on asphalt. As far as the spec motor, I don't think it's needed, they should just run the USGT 21.5 30 degree motor, it's about equivalent to a good 25.5.
R/C Tech Elite Member
Good morning! New to VTA, not new to racing or RC. Limited knowledge on VTA setup vs TC. The question I has is, can someone recommend a baseline setup for an XRAY X4 '22 for medium traction asphalt? I currently am following the box stock asphalt setup, but with the added weight and different tires, I imagine the springs or other aspects of the car may change. Just looking for some insight and advice. Thank you for you time.
Thank you very much!!
Regardless, thank you for the advice and direction. Much appreciated.
