View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
U.S. Vintage Trans-Am Racing Part 2
#4802
Depends on what you mean by "bath", immersed in the actual acetone, or like a vapor sealed container ? I've had experience with the chrome blistering on the wheels, if that helps. I just cut the old tires off with an X-acto knife the best I can and use a Dremel with a grinding/cutting disc to get the rest. works for me.
#4803
I was thinking to soak them in a shallow tub enough to cover one side at a time for a little while just to soften up what is left after cutting the tire off. Then using a dremel with a stiff wire wheel to remove the residuals.
How long did you soak and observed blistering of the chrome? I use the matte chrome wheels so they may not blister as bad or at all?
#4804
From what I remember it was about 6 hours in the container (Tupperware) and noticed the chrome was beginning to blister. The tires did come off easy, with only a little left on the wheels, but the wheels were trashed after that. So now I use the dry method as described previously.
#4805
I use acetone and it did mess with the chrome and the matte chrome but I shoot em black lately so no biggie for me. I leave em in over nite and have even let em go for days and the plastic holds up.
Good question to ask tho since many wheels do not hold up to acetone.
#4806
Here is what I think works the best, or at least for me. I bake them in my over at 250 degrees for about 30 minutes. I pull them out and check them. The tire should break apart from the wheel easily. If not, put them back in for a bit longer. The heat will break down the CA.
Try it, just don't do it at such a hight temp that it melts the tires. I have done this with 4 sets and it works great.
#4807
Don't know much about it. I just assumed that they made a sport version like they did with the T3. It was the same deal as the other kits where it's the same design but with less expensive materials. They are not as good as their more expensive counterparts no matter if it's the T4 or the Spec-R or the Sakura, but VTA does not expose the limits of the cheaper materials so it works pretty good. I think Serpent even has a cheaper version of the S411. Not sure if the BD7 Sport is out yet or not.
#4809
I acteone'd tires off my dyed wheels and they (and the dye) held up fine after being submerged for 24 hours. FWIW, I suspect that tires could've been removed after a few hours. I've also done the same for chrome plated HPI wheels and the chrome starts to flake off. So does the paint. FYI...
#4810
#4815
I bought a gallon of acetone for multipurpose use and also picked up a new empty paint can at Home Depot so I put a couple inches of acetone in the paint can and drop the wheels/tires in and pull em out the next day, if I remember. Which reminds me I've, had some in for a couple days now so, gotta go.
