View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
U.S. Vintage Trans-Am Racing Part 2
#3811
What's a good set up for Mikes in Dallas and how strictly doe they follow the rules? Need to know if I need to buy a driver or not
#3812
J71 body Durability
Hi all,
Any input on the durability of Protoform J71 body? Especially compared to HPI Shelby GT-350.
Cheers,
Otto
Cheers,
Otto
#3813
just a little shoe goo and you'll be good. I've been running the same J71 for 2 years, a little dent here wrinkle there and its still as strong as it was on day 1
#3816
second to the last weekend in Sept every year
pics
http://api.viglink.com/api/click?for...13588697887494
#3818
Crap... that means I'll never get to go; at least as long as I have my current job that is! The second half of August and the whole month of September is fiscal end-of-year for us and we go to a 7 day-a-week work schedule, so unless I get a new position in this company (about as likely as snow in H377) or a completely new job, I guess that's one event I'll never get to participate in!
#3821
I race VTA at Mike's every week and we request that you do run a driver figure. We try and follow the rules as closely as possible but still want to get new people out, generally we give a few weeks to get your car legal.
I hope to see you in some VTA races at Mike's soon. For an example of a good setup for VTA at Mike's, take a look at this VTA setup sheet.
Starting on June 6, 2013, VTA Club races at Mike's Hobby Shop are going to use 100% USVTA Rules exactly as they are posted on USvintageTransAm.com.
Between now and June 6, the VTA rules at Mike's Hobby Shop allow you to use any make 25.5T brushless motor (e.g. Trinity D3 25.5, Viper 25.5, Speed Passion 25.5, etc.). The old rules also do not require a driver figure in the car and the minimum weight limit is 1450 grams.
After June 6 all VTA cars at Mike's will be required to have a driver figure inside the car, use a Novak 3625V or 3425V motor with no modifications, and the minimum weight limit will be 1550 grams.
#3822
Hey LeftyAEguy,
#3824
Novak GTB2 Xdrive LP max drive no drag brake
Novak Ballastic 25.5 38 deg timming w/ LRP fan
FDR 3.69
Robinson 96 spur
Trinity 52 pinion
AE 35 wt oil front
AE 30 wt oil rear
RSD yellow springs front
RSD teal springs rear
AE 40 wt oil rear gear diff
-1 deg camber F/R
Full sauce rear tires
1/2 sauce front tires
Futaba 9551 servo
RSD sway bar collars F/R
1mm washer in front wheels
5mm ride front
5.5mm ride rear
2mm droop F/R
the rest is manual build setup
#3825
