VBC new 1/10 touring car, Wildfire.
#348
not sure but i'm talking about these:
WildFire Suspension Arm Set (Composite Soft) D-05-VBC-0052
http://www.vbcracing.com/collections...-d-05-vbc-0052
#349
Oops. Part number I posted was from crc's site. Here is the vbc number that crc lists. D-05-VBC-0050. http://www.teamcrc.com/crc/modules.p...prodID=7719409 which I think is a typo now that I look further. Because that's the same part number as the motor guard. Anyhow I think we are looking at the same part.
#350
Tech Legend
Trader Rating: 51 (100%+)
Ran my Wildfire for a 2nd time on rubber tire carpet. Only my 2nd time running carpet after my few year layoff. With the help of one of the faster guys at the track he gave me a few suggestions to try and see if I noticed it getting better. The tops guys are super fast so any gain in laptimes is appreciated.
I gained right at 3 tenths faster a lap and when I was running clean was easily 1 1/2 laps faster than the week before. I still have a lot of learning about my car and carpet.
Huge hing was knowing what my car is doing when I drive it so I could explain it to some of the better guys. With this info a few suggestions and bam its feeling way more consistent and easier to drive and thats what I was looking for. Never needed to be the fastest but just was looking for for more consistency for all 6 minutes of the race with the car feeling good from start to finish. I'm 100% closer this week than last. Bad thing is a new layout is going in so now will be harder to gauge for a few runs.
Now for the breakage report. I did break a front steering knuckle but I deserved it with a huge turn in early that sent my brutally into the outside wall at the end of the high speed straightaway. I would say almost any car would of broke something. The other part was a rear belt but again it was fault as I was pissed being stuck on a pipe too long and just smashed the throttle while stuck 3 or 4 times and spun the belt. It was my fault again so not really pissed other than at myself.
Overall I'm learning the car and what it likes for our track so will keep going down the same path and see what happens.
#351
Your car was very good Brian.
Yesterday was my first outing with my new Wildfire as well as my first day back on RUG.... I am very impressed by the car. It reacted well to every change I made and by the end of the day the car was on pace with the normal fast guys at the track. Now if only the driver would step it up......
Looking forward to the rest of the carpet season.
#352
Tech Legend
#355
I'm curious about something. I've only ran a TC6 and it didnt have the belt tensioner, only the cams on the diffs. So whats the point of the tensioner then? If it can be done with the cams. Are the cams a coarse adjustment and the tensioner is more of a fine adjustment? If someone could please explain that it would be greatly appreciated. Or if its been posted before, I'm sure it has, a link would be great.
And a few more questions about the car. The stock shock shafts are not coated at all is that correct?
I'm ready to order this car. Is there anything that I should consider buying with it? I plan to get some of the basic spares (arms, uprights, c-hubs, steering blocks, ball cups, belts). Anything else you guys would recommend? I'll be running this on carpet only in 17.5 blinky. Do sway bars come with it or do I need to buy the various ones?
#356
The standard shock shafts are not coated. The Ti coated ones are nice but not needed. I would use the money and get some spares instead then upgrade them in the future when you have extra cash.
As for spares. I would recommend the normal stuff Steering blocks, c-hubs, rear hubs and maybe a extra set of belts. The car comes with 1.3mm bars front and rear, no option bars included.
#359
Tech Legend
I have the belt tensioner on but like ROn I don't you really need it. I left mine on and just lowered it enough to almost touch the belt. Mainly to just make sure my belt to flap around too much. More of a precaution than anything else.
Time will tell if Teach will keep or sell the Wildfire. Odds in Vegas are just posted and its 100% sure it will be for sale. Hope you keep it awhile longer though. Carpet is tough and takes different setup than asphalt thats for sure.
#360
Tech Legend
I would like to mess with front arm sweep some but right now one thing at a time. I only ever used it on one other touring car but hell for the car I used it on was from at least 5 plus years or more ago. My last cars where the TC5 and then my last car before I took my layoff was the E4RS which I ran on asphatl and loved that car. Smooth and easy to drive.
