New CRC Gen Xi 12th car.....
#721
What are you guys gluing the servos in with? I have heard some use shoe goo but is this really strong enough?
#722
Shoe Goo is more than strong enough. I've never had any electronics come loose that were Shoe Goo'd in. In fact if you do it wrong it will be next to impossible to remove without messing up the chassis...that's really easy to avoid though. To take anything off that has been Shoe Goo'd to the chassis you need to be able to slice the glue with a sharp blade and then it will pry right off. So make sure when using Shoe Goo not to push the component down too far. You need to leave enough gap to wiggle an Xacto blade into.
#723
+1
#724
I don't see the diffuser on the site yet? Must say I looked quickly
#725
What's up All!?!?!
Back for more.
My second go round with 12th scale and went with the Xi. I've had an X but that was waaaay back in the NiMh/ brushed days. I'm doing my homework and reading the x hundred pages to get myself up to speed but any gotchas to look for in the build? Any mandatory upgrades or options? Indoor carpet is gonna be the winter game. Anyhow, any input is much appreciated and it's off to reading I go!!!
Kevin
Back for more.
Kevin
#726
What's up All!?!?!
Back for more.
Kevin
Back for more.
Kevin
Front end:
.50 front springs
long arm set-up
10 degree reactive block
caster shims, 1 forward, the rest back
2 degrees camber
5k lube on kingpins
Black tires
Rear:
White side springs, set just touching plate, no pre-load
20k in tubes
30 wt shock oil
red shock spring
2mm pod droop
Yellow tires
3.5mm ride height front, center, and rear
BlackArt R8C body, mounted based on dimples for front body posts.
If you have any questions post 'em or feel free to PM me.
#727
Welcome back to the game Kevin!!! As far as build is concerned, follow the directions to the letter. As long as nothing is binding you should be good to go. The xi is an awesome ride. Here is my base 17.5 set-up:
Front end:
.50 front springs
long arm set-up
2 degrees camber
5k lube on kingpins
Black tires
Rear:
20k in tubes
30 wt shock oil
red shock spring
2mm pod droop
Yellow tires
Front end:
.50 front springs
long arm set-up
2 degrees camber
5k lube on kingpins
Black tires
Rear:
20k in tubes
30 wt shock oil
red shock spring
2mm pod droop
Yellow tires
It's great to be back, did the off-road thing for my kid but have missed on-road badly!!
I do have another question for this team though.
On my X I ran the Airtronics 94145 servo, it seems on the Xi they have tightened the servo footprint with holes and I can't mount as is. Has anyone successfully got a 94145 mounted on an Xi, if so what did you do? Is there a dremmel in my future to slot the ears on the case? Really didnt want to do that.
Thanks Again Team,
Kevin
#728
My Xti is ordered WHOOOHOOOOO
#729
It doesn't look as if the long upper arm and the Pin braces will work on the XTi? Am I right?
#730
Sorry for all the questions - but does anybody know where your PT will go in the new car?
#731
where can i get a spring set for this car
#732
Raising the upper arms is the more significant tuning option of the two.
Bill
#733
Box Stock Stuff
What's up all,
Having a ball learning about my new ride but have a couple quick questions if you wouldn't mind.
1. What is the weight of thr shock oil included in the Xi kit?
2. What is the tooth count on the spur included? It is 64 pitch correct?
Any input you all have is appreciated!!!!
Kevin
Kevin
#734
What's up all,
Kevin
Kevin
Yes 64p for the spur. I called and asked John at CRC about the oil a few months ago, and all he would tell me was that it is 30 wt. I didn't get any more info than that. I suspect AE 30wt would be really close, or XraY 350CST.
#735
Thanks Again,
Kevin
