Old 09-14-2012, 03:00 PM   #721
tim fry's Avatar
What are you guys gluing the servos in with? I have heard some use shoe goo but is this really strong enough?
tim fry is offline   Reply With Quote
Old 09-14-2012, 03:13 PM   #722
Shoe Goo is more than strong enough. I've never had any electronics come loose that were Shoe Goo'd in. In fact if you do it wrong it will be next to impossible to remove without messing up the chassis...that's really easy to avoid though. To take anything off that has been Shoe Goo'd to the chassis you need to be able to slice the glue with a sharp blade and then it will pry right off. So make sure when using Shoe Goo not to push the component down too far. You need to leave enough gap to wiggle an Xacto blade into.
Old 09-14-2012, 08:21 PM   #723
Still Bill's Avatar
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 09-14-2012, 09:19 PM   #724
FaanP's Avatar
I don't see the diffuser on the site yet? Must say I looked quickly
When in doubt - GAS IT!!
FaanP is offline   Reply With Quote
Old 09-17-2012, 06:27 PM   #725
What's up All!?!?!
Back for more.
My second go round with 12th scale and went with the Xi. I've had an X but that was waaaay back in the NiMh/ brushed days. I'm doing my homework and reading the x hundred pages to get myself up to speed but any gotchas to look for in the build? Any mandatory upgrades or options? Indoor carpet is gonna be the winter game. Anyhow, any input is much appreciated and it's off to reading I go!!!
Kevin
VBC Racing Wildfire D06
VBC Ghost
B4.1 Worlds, Orion R10 Pro/Orion/Orion-Spektrum
Kyosho RT5 Orion R10 Pro/ Viper/Orion
Dave's R/C Racetracks
Leadfinger2011 is offline   Reply With Quote
Old 09-17-2012, 08:17 PM   #726
CypressMidWest's Avatar
Originally Posted by Leadfinger2011 View Post
What's up All!?!?!
Back for more.
Kevin
Welcome back to the game Kevin!!! As far as build is concerned, follow the directions to the letter. As long as nothing is binding you should be good to go. The xi is an awesome ride. Here is my base 17.5 set-up:
Front end:
.50 front springs
long arm set-up
10 degree reactive block
caster shims, 1 forward, the rest back
2 degrees camber
5k lube on kingpins
Black tires
Rear:
White side springs, set just touching plate, no pre-load
20k in tubes
30 wt shock oil
red shock spring
2mm pod droop
Yellow tires
3.5mm ride height front, center, and rear
BlackArt R8C body, mounted based on dimples for front body posts.
If you have any questions post 'em or feel free to PM me.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 09-17-2012, 10:27 PM   #727
Front end:
.50 front springs
long arm set-up
2 degrees camber
5k lube on kingpins
Black tires
Rear:
20k in tubes
30 wt shock oil
red shock spring
2mm pod droop
Yellow tires
Thanks Cypress,
It's great to be back, did the off-road thing for my kid but have missed on-road badly!!
I do have another question for this team though.
On my X I ran the Airtronics 94145 servo, it seems on the Xi they have tightened the servo footprint with holes and I can't mount as is. Has anyone successfully got a 94145 mounted on an Xi, if so what did you do? Is there a dremmel in my future to slot the ears on the case? Really didnt want to do that.
Thanks Again Team,
Kevin
VBC Ghost
Old 09-21-2012, 03:03 AM   #728
FaanP's Avatar
My Xti is ordered WHOOOHOOOOO
Old 09-22-2012, 08:42 AM   #729
FaanP's Avatar
It doesn't look as if the long upper arm and the Pin braces will work on the XTi? Am I right?
Old 09-22-2012, 02:11 PM   #730
FaanP's Avatar
Sorry for all the questions - but does anybody know where your PT will go in the new car?
Old 09-22-2012, 02:21 PM   #731
theatriks's Avatar
where can i get a spring set for this car
theatriks is offline   Reply With Quote
Old 09-22-2012, 05:57 PM   #732
Still Bill's Avatar
Correct. However, you can still raise the upper arms using the two ends of #3277 Graphite Cross Brace (with center piece cut away). And, I believe you could potentially "bridge" over the servo to use the #3276 Graphite Front Top Brace-Short Arms (but not sure if there is enough body clearance for a raised brace). Check with Dumper!
Raising the upper arms is the more significant tuning option of the two.
Bill
Old 09-23-2012, 02:41 PM   #733
Default Box Stock Stuff
What's up all,
Having a ball learning about my new ride but have a couple quick questions if you wouldn't mind.
1. What is the weight of thr shock oil included in the Xi kit?
2. What is the tooth count on the spur included? It is 64 pitch correct?
Any input you all have is appreciated!!!!
Kevin
VBC Ghost
Old 09-23-2012, 04:28 PM   #734
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
What's up all,
Kevin
Yes 64p for the spur. I called and asked John at CRC about the oil a few months ago, and all he would tell me was that it is 30 wt. I didn't get any more info than that. I suspect AE 30wt would be really close, or XraY 350CST.
Old 09-23-2012, 04:34 PM   #735
Thanks Andrew!! Might you know the tooth count on the spur? I thought I would find it on the spur, maybe i missed it but I couldn't see it.
Thanks Again,
Kevin
VBC Ghost
