New CRC Gen Xi 12th car.....
#756
NO!!!!!!!!
drilling the shock cap will cause the bladder to tear. trust me on this one.
#758
#759
I run outdoor asphalt, pretty much stock setting,
Front: camber 1 degree, toe 0.5, 2x pink or magenta tire, traction compound is traction dependence. 5 degree active caster, stock spring, caster all the way back. ride height 4.5
Rear: 7k~10k side oil, white spring, rear center spring, 35~40 center oil, pink tire, full traction compound. ride height 5.0
#760
#762
on the XI what servo position is best (flat or angled) or doesn't matter? Thanks in advance
#763
#765
I honestly couldn't tell much of a difference, most run it flat. I ran mine flat just to get rid of the hardware that comes with running it angled. If you run it flat, I would suggest the links running straight to the outer knuckles and parallel or slightly angled up toward the outside. Hope this helps.
