Like Tree1Likes
Xray T3 2012
Old 11-17-2011, 05:02 PM
  #556
liteweight's Avatar
liteweight is offline
Old 11-17-2011, 05:08 PM
  #557
liteweight's Avatar
Old 11-17-2011, 05:13 PM
  #558
B4james's Avatar
You have the steering levers on upside down, the chamfered edge you can see on the top should be on the bottom.
B4james is offline
Old 11-17-2011, 05:30 PM
  #559
liteweight's Avatar
K Thanks I will try to flip those levers
Old 11-17-2011, 06:26 PM
  #560
theatriks's Avatar
are u guys using the ecs shafts just upfront or all around and if im using a gear diff up front will there still be benefits to the ecs shaft
theatriks is offline
Old 11-17-2011, 06:29 PM
  #561
jgraham37128's Avatar
Trader Rating: 25 (100%+)
I use 52mm ESC's only in the front and use a spool. I've not ran a diff in the front yet so not sure on that one.
JG
jgraham37128 is offline
Old 11-18-2011, 07:25 AM
  #562
M-Technic's Avatar
Trader Rating: 15 (100%+)
There is no reason to run them in the rear.
M-Technic is offline
Old 11-18-2011, 10:42 PM
  #563
bozzplayer's Avatar
Trader Rating: 17 (100%+)
what size of ECS should i run with a Muti-Diff Lipo (part#305105) Ive heard some say you need to run the 50mm ECS others say you need to run the 52mm
bozzplayer is offline
Old 11-19-2011, 01:52 PM
  #564
Ordered mine and it should be here Tuesday. All the LHS shipments are spoken for until probably after the new year so I had to go online.
This is my first touring car since the HPI RS4 Pro 3. I cannot wait to get this thing on the track at 360 v.2 in New Rochelle!
What servos are people using. I ordered the Savox 1258TG. Is this going to fit with a tekin esc and futaba rx? Should I have gotten the 1251?
I think I will go with the Tekin RS for my esc (I have an RS in my SCT and an RS Pro in my 22 and I think the pro is bigger and not necessary for 17.5 blinky).
*edit* What is everyones thoughts on the viper ESCs? They look interesting with that programing card.
What 17.5 blinky motor is working well? I like the thunder power in my sct...and I see reedy has a new one out.
ruknd is offline
Old 11-19-2011, 02:28 PM
  #565
theatriks's Avatar
Had the car out on the carpet today .....stock setup and the car handled beautifully....like it was on rails...love this car so far ....racing tommorow cant wait.
Old 11-19-2011, 09:11 PM
  #566
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
It's a really good idea to run a mid height servo on this car for realistate. I run the ko 2413 for reference. Assuming you don't run a fan and have a small rx you could get away with it.
For 17.5 I have been testing a mix of thunder power, d3 and should have some team powers motors to test soon. The D3 seems to have the biggest sweet spot with good speed. Personally I run the Orion R10 esc in blinky. Great brakes compared to rs pro and other esc's. The only one that comes close is LRP sxx. Given everyone has the same horse power give or take the braking is where you can make up time esp if they are smooth with good modulation. fdr for big tracks is closer to 3.8, smaller tracks 4.2.
Hope this helps.
Originally Posted by Con
Yep me too. I put a 1.10 shim in the left side intsead of the 1.50 shim to compensate.
Seems to have been a problem since the T3 '10.
All my cars since 2008 have been dialed with exactly the same rear toe. Check for excessive torque on fasteners or bent bulkheads etc. If you have older rear hubs swap them out and check that. IIRC a while back there was a batch of 0° hubs that varied a half degree or so. But my 2012 production kit is tits.
Originally Posted by syndr0me
Thanks! So if you've already got the updates to the '11, this is what you need to make a '12?
301132 T3'12 chassis
303087 T3'12 shock tower rear
302086 T3'12 shock tower front
301193 T3'12 upper deck
302526 Composite dual servo saver arm (x2)
372503 Composite servo saver X-stiff
302253 Composite steering block hard (x2)
Adam
The servo saver is a lot better, chassis etc could be called flexi flier should be smokin for asphalt. Had a decent outing with her at the Timezone GP given my radio issues. It does have a pretty wide setup window tho so should work great for the tracks that never really build a groove like some of the co tracks
rx7ttlm is offline
Old 11-19-2011, 09:17 PM
  #567
rx7ttlm's Avatar
DP
rx7ttlm is offline
Old 11-19-2011, 09:18 PM
  #568
Team EAM
Trader Rating: 79 (100%+)
Anyone looking for a T3'12 my local shop has one for 535.00 shipped in the US. PM me for number.
EA
EAMotorsports is offline
Old 11-19-2011, 09:36 PM
  #569
Thanks. That's what I was looking for. I guess I will try the savox I ordered and if it does not work I will go with a low profile and dump the full size in my SCT. This is my first savox so I am curious to see how I will like them.
I went with the Tekin because I have the RS in my SCT and the RS Pro in my TLR 22 and like the throttle control (and reverse for practice). I never thought about the orion. I used to be a big LRP guy. The viper ESCs are peaking my curiosity. I like the adjustability without a computer.
ruknd is offline
Old 11-19-2011, 09:50 PM
  #570
rx7ttlm's Avatar
I had a savox in my 4wd mod buggy and it worked well with good speed and durable (ti gear set). Orion and LRP have great brakes that are easy to modulate. Really most of the esc's can be adjusted without a laptop, tekin, orion, lrp. Personally I prefer the laptop interface but in this case I just rock the hand programmer from orion.
rx7ttlm is offline
