Ta04r...
#1261
TCS GT3 class
GT3 question:
has anyone been experimenting with gearing for the TCS GT3 class with the 04? I plan on running the 04R & was wondering what gearing racers have been trying with the silver cans...any help is appreciated.
(worried by the top speed that the local TL01's are able to acheive)
John
http://groups.yahoo.com/group/tamiyatrf/
John
#1262
TA04R Tub Chassis
Does anyone run Trinity R minus connector plugs (Orion, Integy) with there side by side packs on a tub chassis? Does it fit or will I need convert to battery bars and solder my wires. I just like the convenience of connectors. Currently I have a saddle pack chassis on. I'll be using 2400 and 3000HV cells. Thanks for any help you can give me.
#1263
Regional Moderator
Re: TA04R Tub Chassis
I think if you get the plugs high enough on the battery you may be able to use them. The trick is to make sure you have enough of the bar on the battery to properly fully charge the batteries. I think I'll try this out this week and see how it works.
#1264
Any good setup for the Foam carpet tiers? I have front 42Shore 26MM and rear 40SHore 28 and 30MM...what is the best setup??
#1265
would anyone know if the TA04-SS suspension arms are smaller than the normal TA04 arms?
Thanks in advance!
Thanks in advance!
#1266
Thanks in advance!
Thanks in advance!
and there is one constructed of Hard Material.
#1267
Mike for the 04R there is a Tamiya Chassis seal which might be hard to find or Associated makes a similar product.
Cut it to length of the battery tray and also height slightly taller then line the battery tray with it.
I forgot this on a new 04R chassis I had installed and left a pack in overnight and 3 cells were really dead and 3 were not. oops
As for the "bananna" style plug just solder them up a touch which can be a pain to get through the chassis or put a bar on then solder the connector to it then lay it between the cells like this
\o/ and it will slip in the car just fine
The 04ss arms are different front and rear the fronts ar 3mm shorter and the rears are 7mm shorter to give a total of 10mm shorter wheelbase they also have a touch more webbing to them
#1268
Thanks izzyracer,
would there be short suspension arms for the TA04 other than the SS model?
Thanks you all for your help!
#1269
Thanks Difuser
#1270
Thanks izzyracer,
Thanks izzyracer,
or are you asking if you can buy a different kit with the short wheel base? The answer is One just came out the "Audi"
I don't have part numbers on hand, maybe later.
#1271
Thanks,
either situation will be fine. i'm just looking for a shorter wheelbase so i can try it on a TB III.
#1272
TA04 Tub Chassis
Mike F, Difuser - Thanks for the info about the battery connectors.
#1273
Can somebody please tell me the internal drive ratio of the TA04r Urgent!
#1274
-Whacky.
#1275
Regional Moderator
Originally posted by Difuser
[B]Mike for the 04R there is a Tamiya Chassis seal which might be hard to find or Associated makes a similar product.
I haven't seen or heard of the Chassis seal before. Do you have a part number?
