Team Losi JRXS
R/C Tech Elite Member
Check on the Team Losi website for setups. The Numan setup works really well if you are on asphault tracks, really good starting point. I havent tried any of the carpet rubber setups yet, but I'm sure they are just as good.
The Evicerator
How come Chuck Norris hasn't made his way into this thread yet???
Thank you, POOKYT and Keith.
Itz all joo man!!! Good Luck!
Brant
I've been gone for a while, I decided to run my losi once again after other cars have pissed me off . What are the good things I've missed?
What are the weak parts on the JRXS?
Heys guys, a little help here, just bought a jrxs. What are the weak points(Parts on the car so I can stock up)? Thanks in advance.
Get some spare arms, spindles, and caster blocks and you should be in OK shape. Suspension stuff is always the most common breakage parts.
who is the rubberneck made by?
Just do a search on this website.
And take the time to skim through most of this thread to learn tons about the JRX-S.
Or, just listen to Randy Caster and PookyT......And Todd Hodge.
go there or check with.....
www.kthobbies.com
Kraig usually keeps them in stock as well as a good supply of JRXS parts.
Hope this helps you out!
Brant
How long you been gone and are you running on carpet or Asphalt? Hollar!
Brant
