Team Losi JRXS
#7952
Originally Posted by POOKYT
Just curious but is the steering increase from the forward battery placement or is it from the motor in the rear causing more rotation? Just wondering. Thanks Bill
Brant
P.S. last week I had an order to New Zealand and Canada, this week one to Norway! Thats a total of 10 countries including the USAl Just pretty cool.
Brant
Brant
Brant
#7953
Guys, I've been running my LCD/CVD drive shafts with bearings for about 6 weeks now, and I've had to replace the bearings in the front (LCD) twice now. Has anyone experience the same?
I'm running the spool diff, so I was wondering if this contributed to the bearings collapsing.
Any thoughts?
Any thoughts?
#7955
I don't mean to complain, but
I'm new to this hobby and the JRXS is my first kit. My first car was an RTR TC4, which I have now stripped down to the bare parts and rebuilt several times (to learn and to fix crash damage).
The JRXS seems to need much more grinding and filing than I would have expected for a high end kit. For example, I don't understand why Losi does not mold the rear battery slot so that it fits correctly. Similarly, why do we need to grind away at the chassis to get clearance for the belts when the diffs are set low? Also, why do we have to grind out the front brackets that hold the steering knuckles so that the LCDs will not rub?
It seems to me that all of these things could have been taken care of with proper molding of the parts. I've been working on building this kit for a 4 days. I'm going slowly and carefully and I just can't believe how long it is taking.
The car still looks cool and I really like many of the innovative features, but Losi is making me work hard to enjoy them.
Ira
Ira
#7956
Ira
Ira
That's why it is called a hobby!!! You do have to work and use some skill and expertise to get a good finished product, it separates the good cars from the ones just 'thrown' together.
Also it would cost a whole lotta dough to set up a 3D machining rig to do the work required, and don't even think about all the different battery sizes......
Once you have built a few high end tourers you will be able to breeze through a car like this, mine would have taken less than a day to build, and I didn't rush it.
#7957
Ira
Ira
#7960
#7961
However, with respect to the parts fitting, lets face it, Losi had to cut out the holes in the chassis for the pulleys and the rear battery. Why would it have cost extra to make these holes actually fit the intended parts?
As for battery sizes, make it fit the standard 3300 mAh cell, then if people want larger cells, ok, file away.
For the belt clearance issue, there is no excuse. The hole is already there, just taper it or make it a tad longer. They already tapered some of the holes, no biggie for one more.
Similarly, why aren't the countersunk holes consistent? I have lots of screws on the bottom of my chassis that are not quite flush. Why are the holes in many of the top plates not quite drilled out to the right size. Why was a rear piviot block pin hole on my chassis not drilled out to the right size? Yes, I got out my drill and fixed it, but I would rather be finished and tuning the suspension already.
The car is nicely designed, but I don't understand why it is a measure of my dedication to the hobby to overcome production variances and problems.
Ira
#7962
Ira
Ira
#7964
Someone else over here running a JRX-S ..... curious
Brant
#7965
Originally Posted by robk
Too bad you never had the experience of building an original RC10 gold chassis car. You would have quit before you started.
Brant
