Team Losi JRXS
#9452
Originally Posted by Bink
Todd-
I am currently running 70 weight oil in the front with 60 rate springs and 30 weight oil in the rear with 25 rate springs with the original kit arms on carpet. When using the new BK arms on carpet, what shock oil and spring rates do you suggest on my current setup?
For springs I used 30lb front and 20lb rear.
#9453
cs27 carpet set-up-partial
OK-heres the set-up on the car.
Front
6 deg caster
Camber link middle hole inside.
Steering stock (no bump shims)
high roll rear block, low roll front block and raised 0.050". 1 deg toe block.
Shocks middle hole on tower, 35 lb spring, 60 wt. oil #60
diff low, mid wheelbase.
Rear
standard 0deg hubs, 2 deg inner toe in.
Camber link middle row-middle hole. Outside on hub and raised 0.030" short ballstud.
Shocks out on arm, three in on tower. 17.5 lb spring 40 wt. oil # 57
sway bar (third thickest in kit
diff high, mid wheelbase.
Thats all for now. I'll add more later.
Front
6 deg caster
Rear
#9458
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Originally Posted by POOKYT
MRJOLLY--Yes they are but visit this page to make sure you check your clearances on all of them. http://www.teamlosi.com/jrxs-page/trick%20tip%20pg2.htm
Hope this helps Mate!!
Brant
Brant
#9459
Gary
i would like to try the double one way setup....i had that 414x that had that....it worked there....
#9461
cool....good luck....
#9462
Originally Posted by bigdog xxx-s
Brant you missed the part where I said "or" 1 deg rear toe bar and 1 deg hugs flipped to get 2 deg. Still wondering which way is better, or if it makes a difference.
Brant
#9463
hey guys, another newbie question for you;
is there supposed to be a white O-ring that sits at the base of the top threads of the shock? (where the top cap would thread down to) I purchased my kit pre-assembled, and am suspect if these were assembled correctly. I'm thinking that these white O-rings might actually be for the spring preload adjusters....
thanks again.
thanks again.
#9465
Front
6 deg caster
high roll rear block, low roll front block and raised 0.050". 0 deg toe block.
Rear
Front
6 deg caster
Rear
