Ask Steve "The Evicerator" Weiss >
Old 04-13-2009, 02:51 PM
  #6841
The Evicerator
Hey Tony,
I haven't heard from her.
Lately I have been running either a Mazdaspeed 6 or a LTC-R... both seemed to work pretty well up at Speedworld this past weekend... but I have a feeling most people will be running MazdaSpeeds!
Originally Posted by tmunno
Steve, did Toni im/e-mail/or call you yet? If so then she know's what type body style works there. We run Mazda 6 in Fl./rubber tires on asphalt. Lynn has to paint her up something to run as she wants to race the Reedy this year. Please let me know so I can get her taken care of. Thanks Tony.
Steve Weiss is offline
Old 04-13-2009, 03:10 PM
  #6842
racer x 1's Avatar
Trader Rating: 27 (100%+)
Hey Steve can i get an fdr for a 13.5 running at bending corners? Thanks
racer x 1 is offline
Old 04-13-2009, 03:29 PM
  #6843
bigb11's Avatar
Trader Rating: 59 (100%+)
Steve, has Novak come out with the sensor wire extension for the 380 motor?
bigb11 is offline
Old 04-13-2009, 03:39 PM
  #6844
The Evicerator
What ESC are you running? What settings?
We have talked about offering sensor wire extentions, but I'm really not sure where that project sits at the moment! Once the big bosses are back and settled from their trip I'll see what I can find out!
Old 04-13-2009, 04:12 PM
  #6845
tmunno's Avatar
Thank you sir. We can not attend but at least the kid gets to go!!!!!!
tmunno is offline
Old 04-13-2009, 04:17 PM
  #6846
bigb11's Avatar
Thank you, Steve hope they do that sensor wire soon.
bigb11 is offline
Old 04-14-2009, 08:13 AM
  #6847
The Evicerator
No problem!!
Old 04-14-2009, 08:36 AM
  #6848
racer x 1's Avatar
im running a gtb on profile 3
Old 04-15-2009, 08:10 AM
  #6849
The Evicerator
Try 4.5 and go up from there if temperatures/speed allows.
You don't want your motor more than 160 degrees after a 5 minute run.
Old 04-15-2009, 09:33 AM
  #6850
timmay70's Avatar
How about after a 6 minute run (now that ROAR is all 6 minutes...)?
timmay70 is offline
Old 04-15-2009, 10:41 AM
  #6851
The Evicerator
Same temperature. If you were running for 10 minutes with the 5 minute gearing/160 degree gearing you'd probably wind up running hotter than 160
Old 04-15-2009, 07:51 PM
  #6852
Airflow's Avatar
Hi Steve...
I have an incoming 10.5 EX motor and a used Velocity motor.
Can I transfer the inner components of the 10.5 EX motor into
the Velocity motor can? I just want to use its ribbed can and
oversized front bearing and possibly the sintered rotor of
the velocity motor.
Airflow is offline
Old 04-15-2009, 09:01 PM
  #6853
Scott B's Avatar
Trader Rating: 47 (100%+)
Steve you have a PM!!!
Scott B is online now
Old 04-16-2009, 07:14 AM
  #6854
racer x 1's Avatar
thks steve
Old 04-16-2009, 01:14 PM
  #6855
linger's Avatar
Hey Steve,
What's the difference between the #5908 12.3mm sintered rotor and the upcoming #5941 12.3mm Ballisitc sintered rotor?
Are they interchangeable? Is one better than the other?
linger is offline
