Ask Steve "The Evicerator" Weiss >
Old 04-24-2008, 03:38 PM
  #6121
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Double chocolate chocolate chip cookies or regular chocolate chip cookies?
Syber Serulean is offline
Old 04-24-2008, 03:42 PM
  #6122
The Evicerator
Double Chocolate Chip!
Steve Weiss is offline
  #6123
couldnt agree more.
Old 04-24-2008, 08:28 PM
  #6124
metalracer2's Avatar
Trader Rating: 20 (100%+)
cookies
those are my cookies!!!!!
metalracer2 is offline
Old 04-24-2008, 09:06 PM
  #6125
Mr. Shookie's Avatar
Hey Steve,
Hope your day is a blessed one.
Hope to back out racing soon,
-Shookie <><
Mr. Shookie is offline
Old 04-25-2008, 08:11 AM
  #6126
The Evicerator
Thanks shookie!
Same to you!
I hope you're feeling better and to see you again soon!
Originally Posted by Mr. Shookie
Hey Steve,
-Shookie <><
Old 04-25-2008, 01:34 PM
  #6127
Questions?? TOOOOO much Technology for an old fart !!!!!
I recently upgraded my Futaba radio to the FASST system. We are presently between our winter indoor season and asphalt outdoor season so I havent used it yet.
(1) I presently have a 4cell GTB for 1/12 scale and also just got a spread spectrum 4cell GTB. Will I need to run a receiver pack with 4cell because of the voltage. All the 1/12 racing will be done indoor on carpet. I guess thats actually a guestion for Futaba.
(2) I have 2 older GTBS for 6 cell 1/10 pancar and 6cell touring and an original 5800SS. I have read posts where GTB's have gone up in smoke when the ESC is turned off, but the battery is still plugged in, and the front wheels are turned. I have vehicles, some with digital and some with analog servos. What do I need to do or buy to avoid the "SMOKING GTB" sydrome. I am using NIMH batteries now, but the LIPOS are probably just around the corner.
Any suggestions and advice will be greatly appreciated. Or is time for me to sell everything and buy something from Radio Shack and build a track behind the seniors home!!!!!!
THEBIGBULL is offline
Old 04-25-2008, 01:43 PM
  #6128
Regional Moderator
CarbonJoe's Avatar
I use a Spread Spectrum GTB 4 cell, with both 17.5 and 13.5 motors, and no Rx pack, without issues. This is with a Spektrum micro receiver.
CarbonJoe is offline
Old 04-25-2008, 01:45 PM
  #6129
The Evicerator
Big Bull,
1.) Most of the time guys get away without running receiver packs...but certain radio systems seem to be more sensitive to low voltage operation than others.
2.) Send us a self-addressed and stamped envelope with a note requesting some of the Servo Protection Harnesses. Please note how many you need and which length (4" or 9") you require.
Old 04-25-2008, 02:14 PM
  #6130
Big Bull,
Steve,
Is there a specific batch or range of serial #'s affected by this issue?
vagiburn is offline
Old 04-25-2008, 02:16 PM
  #6131
The Evicerator
vagi,
Everything at this point is susceptible to this damage.
Old 04-25-2008, 02:35 PM
  #6132
MarkBrown's Avatar
2.) Send us a self-addressed and stamped envelope with a note requesting some of the Servo Protection Harnesses. ...
When the ESC is switched off I thought the BEC regulator power was turned off as well, so the steering servo should not care that is is off-center. So I don't understand the source of the problem that these harnesses solve.
My next question would be, how do the harnesses solve the problem and why are they a (free) add-on rather than being standard? Is there a downside to using one?
MarkBrown is offline
Old 04-25-2008, 03:23 PM
  #6133
The Evicerator
Mark,
Every servo has a motor inside of it, and if the servo is moved the motor then inadvertantly acts like a generator... if the servo is moved enough, the voltage can be high enough to travel back through the servo lead, through the receiver and into the ESC. This stray voltage can cause the gates to the transistors to turn on... without the "brain" of the ESC being on to control what happens. If there is a battery connected the transistors can turn on and have enough power to short out to one another.
These harnesses have a diode built inline to the red "power" wire of the ESC. The function of a diode is to allow electricity to flow one way, but not the other... effectively like a one way valve.
This diode is positioned so that when the ESC is on, the BEC can properly power your receiver, and servo. Regardless of whether the servo is on or off however, power will not be able to "go backward" into the ESC potentially causing damage.
There is a very small voltage drop associated with a diode, bringing the BEC output voltage down slightly from 6.0/6.1V to 5.9 or 5.8 V.
Old 04-25-2008, 05:55 PM
  #6134
Thumbs up Re...Smoke show
Thanks, Steve for the almost instantanious answer, I will send a letter tomorrow. I guess the way to see if I need a receiver pack or not is to try it with out one "EH".
BE
TJ
Old 04-26-2008, 08:14 AM
  #6135
Thumbs up
I just wanted to publicly call out Novak and particularly Steve Weiss after my latest dealings with them. Due to some unfortunate racing luck, I had the sensor wires in my 10.5 motor cut as well as a bearing that failed in my 13.5 motor. I contacted Steve, sent out my stuff for repair this past Monday and had everything back in my hands this past Thursday. A three day turnaround, door to door. I'd like to thank Steve and Novak for their continuing outstanding service and for setting the standard of how to treat customers in this industry.
Eric Dimmick
Darkside Motorsports
THE DARKSIDE is offline
