Ask Steve "The Evicerator" Weiss >
Old 02-12-2008, 04:18 PM
  #5881
The Evicerator
Generally it gives a more natual drag brake feel... more over-all brakes... more consistant brakes through the end of the run.
You generally have to gear up the motor about 2 teeth on the pinion to get the top speed back.
Steve Weiss is offline
Old 02-12-2008, 05:27 PM
  #5882
HVFracingwilly's Avatar
Trader Rating: 17 (100%+)
Dont know if i missed a special announcement or not but where have all the Novak motors gone on backorder almost everywhere???
HVFracingwilly is offline
Old 02-13-2008, 07:53 AM
  #5883
The Evicerator
Everything should be moving out the door steadily now... we had to wait on parts to complete the motors for shipment... but I believe everything is all sorted out now!
Old 02-14-2008, 08:16 AM
  #5884
The Evicerator
For anyone interested in some non-novak silliness I posted a rediculous video up on my myspace last night ... myspace.com/skubasteve79
Old 02-14-2008, 08:19 AM
  #5885
DavidAlford's Avatar
Trader Rating: 32 (100%+)
look at you turning your thread into a free myspace plug lol
DavidAlford is offline
Old 02-14-2008, 08:25 AM
  #5886
A double post 6 minutes apart. I rule
Old 02-14-2008, 01:50 PM
  #5887
BJ
Man...I always get screwed over on this. Gear up is that like bigger pinion or smaller?????
Dam
BJ is offline
Old 02-14-2008, 02:51 PM
  #5888
The Evicerator
Gear up = bigger pinion gear
Dam
Old 02-16-2008, 09:51 PM
  #5889
Trader Rating: 49 (95%+)
Hey Steve got an odd thing happening to a guy at my local track. Running a 3.5r sintered rotor on 6 cell 4200's with a GTB, anyway last Sat about two min's into the main, car just stops, well the rotor blew basically. The rotor was in about 20 pieces. So today, he buys a brand new rotor, runs a pack through it, no prob, second pack, two laps bang, same thing, rotor just blew apart. I'll attach a pic later. He bought a new 3.5 motor and ran the rest of the night with no issues. So he was wondering what is causing this exploding rotor syndrome?
loopedout is offline
Old 02-16-2008, 10:12 PM
  #5890
stew215's Avatar
Trader Rating: 16 (100%+)
Default problem
i dropped my novak brushless motor and the surface mount capacitors between a b and c broke off is there anywhere i can get new ones or should i just get a new motor ?
stew215 is offline
Old 02-17-2008, 09:38 AM
  #5891
The Evicerator
Looped
that seems pretty strange, what was he geared? How big is the track?
Old 02-17-2008, 09:41 AM
  #5892
The Evicerator
stew
The caps are not important... In fact we have stopped installing them in the motors here because they seem to work better without them
Old 02-17-2008, 10:14 AM
  #5893
stew215's Avatar
the motor is not working right without the caps. it runs until i hit the break then the green and blue lights come up on my esc and it woulnt run after that
stew215 is offline
Old 02-17-2008, 10:16 AM
  #5894
The Evicerator
Stew,
Then what's broken off are not the capacitors like I thought... but the sensors inside the motor.
You can send the motor in to get replaced... it should be cheaper than buying a whole new motor!
Old 02-17-2008, 10:23 AM
  #5895
stew215's Avatar
it just seems like it doesn't have the voltage to move the motor cause if i spin it then hit the throttle it runs good but when i try to start it when its still the motor doesn't go anywhere
but anyway how much is a replacement for a 4300 ?
-thanks
stew215 is offline
