Ask Steve "The Evicerator" Weiss
#6631
GTB & 13.5 SS
I sent a PM to Steve on Saturday and have not received a response, maybe someone else can give me some advice on this. I am in the process of installing both in my TC5R. The instructions and all the picks I have seen up to now show holes in the motor tabs to insert the wires into and then solder. The motor I have does not have holes in the tabs. Is this someting new? Or is this standard? If it is standard how/where do you recommend attaching them? The tabs have a lip on them, should I attach them to the lip or bend the wire around and solder to the outside flat edge of the tab? I also noticed there is plastic on the inner part of the tabs.
#6632
I don't think any Novak motors have the holes.
#6633
http://www.teamnovak.com/tech_info/h...tor/index.html
I notice the magnetic is very strong in this new rotor. Will I get more torque or my car will run much faster?
#6634
Hi Steve, need help installing the Novak 2 cell smart stop blue LED light.
is the red wire soppose to be on the outside or the black wire? or do i just match up the red wire with the red wire on the back of the smartstop chip and black wire to the black wire back of the chip?
#6635
XBR vs Havoc
I raised this question on some other forums. maybe I should have just asked it here, so I will now.
Both the XBR and Havoc have the same brushless motor limit of 8.5 turns. This would imply to me that the internals (FETs & stuff) are similar.
Why is the Havoc limited to a 27 turn (540 size) motor in brushed mode while the XBR was listed as "no motor limit" in brushed mode?
#6637
Catalyst is right. You SHOULD NOT use an AM, FM, or PCM radio system with a SPREAD SPECTRUM GTB.
You should only use 2.4 Ghz systems with the SPREAD SPECTRUM GTB.
Both the Spread Spectrum and Standard 6 cell GTB's we have been shipping for well over a year now have built in lipo cut off circuitry.
Would this explain why my SS GTB works intermittently? I use a JR 40mhz Synth radio. Can the GTB be damaged using a non 2.4ghz radio? Cheers
#6638
The Evicerator
Hi Guys,
First off, sorry about the delayed responses...been really sick for a few weeks now...just starting to feel better.
If I miss any questions from PM or on here PLEASE feel free to repost.
Ok, you were having runtime/heating problems right...? Sounds like everything is about right... how big is your track? Do you have the timing on your motor turned up at all...?
Jay,
The minimum drive shouldn't effect the top end power at all.... but I think I can understand why you're seeing that effect... Sometimes when a battery is loaded hard it will not recover to full voltage for a few seconds... if your minimum drive is set higher, it can "hit" the battery harder initially...causing the recovery time to be longer...which could give the appearance of less top end speed.
Yeahyeah,
I would put the differences you're seeing on the track down to the batteries... brushless motors can be pretty sensitive to minor fluctuations in battery performance. If your pack is not charged all the way it can show on the track. If your pack is peaking off at 8.15 V more than likely the charger is monitoring both cells in the pack...and one might be at 4.2... The other then could be much lower...resulting in the 8.15 total voltage... I would be sure to balance your packs more and maybe cycle the packs to make sure they're not going bad on you.
Sorry about the delay in getting back to you...been sick and not really up for spending lots of time on the PC.
Simply solder the motor wires to the tops of the tabs. This new style motor tab has been standard for quite a while now... We have found that most people have an easier time soldering to them and they give better resistance than the old PCB style with holes in them.
Toh,
You should definately notice more torque... but you should gear up two teeth on the pinion gear to "get back" top speed you had with your bonded rotor.
Overall motor performance should be much better now though.
The black wire should be on the outside if I remember correctly.
The internals are very similar, we recommended the 27 turn motor only for saftey reasons.
With a lipo or 6 cell battery pack around 9.5.
Dave,
40mhz radios tend to output much less powerful signals than their 75/27 mhz brothers due to regulational requirements. If the outgoing signal is weaker, it will be much more susceptible to glitching and radio interferance than 27/75 or 2.4 Ghz.
Hi Steve,
Is it possible for a motor to perform differently if ran several times a day eg 5 times
I run a 13.5 pro and lipos
For no apparent reason in any one of the 5 rounds my car is slower in a straight line.Basically unpredictable. I run the same gear ratio in all 5 races.
Using rubber tyres. (lets assume my car is well maintained and doesnt have any binding or poorly prepared issues)
Also how can I tell if my lipo charger is peaking correctly
Should my lipo pack always peak at 8.4v
I have seen my packs cut off at say 8.15v at times and I hit repeak then my charger may put few milliamps in then cutoffs after few seconds so its stating the fact that it assumes the pack has peaked correctly.
I do balance charge once a week night before I race
Your thoughts?
Your thoughts?
I had my rotor replaced with Sintered rotor #5909 & followed the instructions given below:
#6639
Hey SuperSteve,
Firstly, Happy Holidays!!
Having a problem with my GTB (LiPo, non SS). Powered up it will run the motor at full throttle but cuts out every couple seconds until after 5-6 seconds it shuts down. Will usually start up again (though for shorter time) if I wait several seconds then hit the throttle again. Neither the motor nor the esc exhibit any heat. This was tested with 2 different motors (both Novak 13.5's).
Ideas?
Thanks,
Scottrik
Ideas?
Thanks,
Scottrik
#6640
The Evicerator
It sort of sounds like you have the lipo cut off turned on... and that the ESC is going into saftey cut off.
Be sure that the batteries are fully charged.
You might want to try turning the shut off off just to confirm one way or the other if that's what's causing the problem.
Hey SuperSteve,
Ideas?
Thanks,
Scottrik
Ideas?
Thanks,
Scottrik
#6641
Last time it was used was in a LiPo application. Was installing it in my WGT car on 4-cell. Batteries were DEFINITELY fully charged, but significantly below the cut-off value for voltage in a LiPo application.
"Problem" solved...whew!
Many thanks Steve, and Happy New Year to you!
Scottrik
#6642
GTB 4 cell problem
Steve,
I have been using a GTB 4 cell with the 13.5 BL motor...changed to a 17.5. When I hooked everything up, the LED lights on the ESC don't come on and no motor response. Tried to one step program with no response either. Everything else works fine, e.g., steering servo, transponder and ESC on/off switch. Any thoughts?
#6643
Hi Steve,
Would just like to ask you a questions about gearing the 17.5SS Pro. I am running an Xray T2 '008 (1.7 IR) with an LRP Sphere Comp TC ESC and run @ Trackside (Milwaukee, WI) I checked the Novak site and it says to start out at a 3.5 FDR, but I was running today with about a 4.0 ratio and the motor temped out at about 185F after a 5 min heat race. I am getting pulled pretty hard down the straight but with the temp I know that I can't gear up any more. Any suggestions?
Thanks,
Jeremy
Thanks,
Jeremy
#6644
runtime is still touchy as in transponder stops counting with about 3 laps to go sometimes, thats using fresh Trinity IB4600 with 480 sec at 35 amp numbers, heating issue is gone with using the GTB, track is a 170' tri oval, timing is at factory setting
#6645
The Evicerator
Steve,
Hi Steve,
Thanks,
Jeremy
Thanks,
Jeremy
Try using a lower "punch" setting and see what happens. Hopefully the rotor hasn't been damaged due to the timing/current... if it has it might have been weakened and will not perform as well as a rotor that was never overheated.
