PRC Quad12
#227
Saw this link while looking at the 1/12 forum right here on RCT.
http://www.rc-cross.com/page/1_2parts.html
Scoll to the bottom of the page.
They say that imitation is the most sincere form of flattery. You decide.
D.P.
D.P.
#228
I saw that too Doug. Hey any chance you can make the piece that we were supposed to look at on that page? I would like to try one.
Let me know when the other stuff will be sent too. I'm sure Adam is waiting on the same thing.
Thanks for everything.
Tim
Tim
#231
Location: Redford Mi. Trying to keep up with Tim Stamper
Adam ,
I saw you called last week , sorry for not returning the call . I'm in paint mode now , so if you need some thing for cleveland , get it to me ASAP . I'm soooo unprepared for the champs this year , I've only been on the rug twice , and looks like this weekend is out too , so CRL then the champs . see ya there .
Bob
Bob
#232
Does anyone here run TRC tires with your Quad12? If so, how many shims does it take to get your rear tires to 6.75"? I have the IRS rear pod plates and the IRS axle. I have the hub reversed on the left side which moves the tire out enough to clear the lower pod. At this point I am still adding 2-3 associated shims to the left side and 15-16 shims on the right side. This centers the axle perfectly (measured at the notch on the lower pod) and the tires are just under 6.75". Is it normal to need that many shims? If so, any ideas where to buy thicker shims? One shim that is .1" would be just about perfect.
#233
I've used TRC tires but I don't remember needing that many shims on the right side. It sounds like you might need a 10L2 axle spacer on that side.
D.P.
#234
Doug,
Thanks for the tip. Any idea how thick those are? They don't seem to be listed on Associated's web site anymore. Any idea where to get some?
Thanks!!
Thanks!!
#235
Doug,
Thanks!!
Doug,
Thanks!!
They are right at .125" in thickness. They may be a 10L3 part also. I will find the part number and let you know.
D.P.
#236
Doug,
I found a part # (8231). If they are .125 it would put me over 6.75".
Deric
Deric
#237
get spaced
On my Q12 I use a Niftech .1" (aluminum) spacer with a Niftech .030" shim (phenolic) on the gear side; and an IRS hub set long side in with a Niftech .030" on the left. This gives me perfect centering and full 172 mm width. This is with Niftech motor bulkheads.
O'D
O'D
#238
O'D,
That sounds perfect. Got a part # for the .1 spacer?
Thanks!!
Thanks!!
#239
We're talking Niftech here, you call, you ask, they send.
Seriously, though, I don't know if it's in the catalog, but if you call Niftech you can order it.
O'D
O'D
#240
Cool. I will give them a call!!
