Team Associated TC4
I posted this in the USVTA section but I think I should have posted here. I have a TC4 that I'm setting up for VTA. What body posts are people using to mount their VTA bodies? I have the stock ones on right now but the front seems too low and needs to go up 1-2 more holes. Is there an aftermarket one people use with the TC4?
Would save me a bomb of money if I could make the Tc3 quick enough to keep up with the other cars in the 17.5t class..
I think I have read that there is NOT a gear diff option but I can get a front spool
I will be racing on carpet so any advice on modding the chassis or setup advice would be great.
The TC4 suspension parts are NOT compatible with the TC3. None of them. I tried. On each part there is at the very least one measurement which differs from the TC3 parts. Maybe the C-hubs would fit but I'm not even sure. Besides, the TC3 has always had a better reputation than the TC4 performance-wise.
No gear diff and not needed. A well built steel diff with ceramic balls everywhere lasts forever.
Front spool : yes, can do, but you'll go through front CVD bones like crazy. They wear at the hole where the pin goes. The TC4 units are less prone to bending but the wear problem remains. And since steel units are basically impossible to find, you're better off running a second steel diff ball up front, only build it with stock 5/64 balls, ceramic thrust and set it really tight.
Apart from that, if you want to race your tc3, be prepared to have spare inner hinge pins, they bend if you look at them wrong.
Aluminum steering knuckles are also a welcome hop-up.
Sincerely, as much as I LOVE the TC3, -I really do- the Spec-R S1 or R1 seem like a much better deal for your money. 4 steel cvd's, probably better shocks than the old AE units, etc...
YES it's possible to run a TC3 and be fast with it , but it's neither easy nor cheap. For all the little parts I just mentioned the bill almost amounts the price of a Spec-r delivered to your door. Save yourself the trouble and go for the Spec-R. Having wrenched a sakura S once , I wouldn't recommend it.
2. get some tire compound ... SXT works great
3. your front tires look worn, get a new set.
Also get rid of the solid servo to steering link, put a normal turnbuckle in there ... those plastic ones flex a lot.
2013 SNOWBIRDS pics & video
No gear diff and not needed. A well built steel diff with ceramic balls everywhere last forever.
Front spool : yes, can do, but you'll go through front CVD bones like crazy. They wear at the hole where the pin goes. The TC4 units are less prone to bending but the wear problem remains. And since steel units are basically impossible to find, you're better off running a second diff ball up front, only build it with stock 5/64 balls, ceramic thrust and set it really tight.
steel units are basically impossible to find ... really
here you go :
http://www.teamassociated.com/parts/details/2402/
http://www3.towerhobbies.com/cgi-bin...?&I=LXCZD1&P=7
http://store.rcspeed.net/catalog/pro...roducts_id=265
http://www.ebay.com/sch/i.html?_odkw...+2402&_sacat=0
Also for those worried or complaining about a spool damaging parts in a crash, just use the TC5 slipper spool pads instead of the diff rings and balls and the problem is solved. The slipper spool ideas is one of the best ones our there and it surprises me more companies don't offer one for their cars.
I have run TC3 arms on my TC4 by drilling out the inner hinge pin hole in the arms, I have also run TC4 arms on my TC3 by drilling out the arm mounts. If you know how to use a drill bit you can make most TC3-TC4 parts compatible, the ONLY parts not compatible are the chassis, bumper & arm mount blocks ... yes you can even make the TC4 steering work on a TC3 with a dremel, been done lots of times before. Heck there are even losi parts that are compatible with the TC3 & TC4
here you go :
here you go :
As for the suspension parts... yeah with a dremel lots of things are possible, I even fitted the whole suspension from my Cyclone on a TC3 chassis (seriously). But suggesting it to our friend Andy wouldn't help him much, would it ?
About the micro-pro diff, I thought of that guy's mod ( super nicely made btw) but like you said it is questionable wether it's worth the effort. The diff in itself requires quite a bit of work to be usable. (In case someone really wants to know I can tell you what I had to do to be able to use one in my Photon).
So, again, my point : get the spec-R car.
Thanks a ton for the links. I must say I've been looking for a long time, with tons of different key word and I can't believe I never stumbled upon those. Thanks.
Get a spec-r ??? no thanks ... I like my TC3 & TC4
ps you do realize its not shaft drive like TC3 & TC4
You dont need a dremel to use TC4 suspension parts on a TC3, just a drill bit, the only difference is the inner hinge pin size. When using TC4 Castor Blocks on a TC3 you need to drill 2 small holes for 2-56 screws in the arm to hold the hinge pin ... just like the TC4 has. You cant get TC3 4* castor blocks anymore but this way you can use TC4 castor blocks
Nice website !
Forget about the Spec-R ! It's either convert your tc3 to a tc4 or get a new tc4 !!!!
By the way, getting a tc3 that you loved and cherished for years to compete is not about cost, it's about taking on a challenge and succeeding !
