Team Associated TC4
#9736
Hi
TC4Racer123,
have you tried using 10.5t with boost/turbo on ur tc4? Can give me setups and parts to have 4 spare. Races in my country starting to use 10.5t. Before was using 11.5t. I new with Tc4. Just normal TC4 not the FTTc4. Really need advise.
TC4Racer123,
#9737
Well I don't 10.5t. We used to race 13.5, now we race 17.5. Anyway, what kind of track are you running on?? Asphalt or carpet? Do you have the parma hard front bumper mentioned earlier? Its extremely helpful. I really need to know what kind of track your running on.
#9738
We run on tarmac , track size varies as it a make shift track(parking lot). No dont't have the parma hard front bumper. don't think can get it here locally. We going to have 13.5 and 17.5 races but most probably next year.
#9739
Hi all, I just acquired a used FT TC4 locally on craig's list, I actually traded a Traxxas Rustler vxl roller for the thing and its also my very first Associated car. I currently race 17.5tc with an HPI sprint 2 and have been having stellar results with the hpi, but I have been looking for a more competitive chassis and this thing basically fell into my lap. I plan on using this as my new carpet chassis since I am on a tight budget and cannot afford a fancy Xray or TRF etc.. I printed myself up a manual for the car off of the FT website and have figured out that I am missing a few parts here and there. SO, what I need to know is how to set this thing up for the carpet running rubber tires and what parts I will need. I am missing the chassis spline plate and mounts and I am missing the standoffs as well as the swaybars. From the looks of it all of the suspension geometry is stock and un-tampered with. The only thing that has been changed is the springs/ride height and the removal of the swaybars etc(it was previously a drifter). It has the standard CF upper and lower chassis not the ITF. I looked around the net for setup's for rubber on carpet and found a few but they varied greatly and I just need a solid starting point w/a little bit a push so I can start to understand the car. I still need to replace the diff housings due to stripped out lowers, and replace all of the hardware as it is all stripped out. This will be a build in progress and I will be checking back here frequently for help. I will be using a Tekin RS/17.5redline combo and the track I run on is currently a scale replica of the 2010 IIC Vegas setup and since its so awesome I assume it will stay this way for a few months. Thanks ahead for your help!
#9740
Digital Servo for TC4
Have a new TC4. Updated to brushless and Lipo. Very happy with everything except for how it 'tracks'. I think the analog server needs replacing. It just does not want to stay centered (nothing is loose or broken).
Thoughts on a good servo at a reasonable price?
How about this Airtec ??
#9741
Just keep in mind, if your servo isnt a metal gear servo, then this trick will leave your servo gears more vulnerable to breakage. There always seems to be a negative with something positive...
#9742
Dan
#9743
What servo saver spring is in the steering rack? If it is the stock spring, then it will never center regardless of the servo you purchase. Its common to use a diff spring in its place. Compress the diff spring completely and just barely back it off.
Appreciate the great tip!
#9744
I still use analog servos, Airtronics 94357's and they center very well. Although i have heard some people complain about centering issues with them, i have yet to have a problem, or felt the need to make the step to digital servos. I just hate to spend $ on something if i dont really need to.
I dedicate one servo for TC, and others for my offroad classes... i never mix and match. Offroad and larger scale chassis seem much harder on servo internals (not only the gears, but the electrical parts too), and seem to degrade much faster.
I only mention that, wondering if you had your current servo in a truck or something of that nature. If so that may have created a centering issue with your current servo, and it would be more noticeable in a more responsive chassis such as a TC.
#9745
Thanks TC4Racer123 will give it a try.
Cheers
Cheers
#9746
#9747
No problem.
Issue now is springs and possible sway bar. I am a little fishy out of the turns and have to be careful with the throttle or I will end up sideways.
Thoughts? Looking to go to SILVER and GREEN for front and rear respectively. I run on asphalt (very smooth and fast).
#9748
I would try and stay away from the swaybar if you could. You can end up with a faster car if it is setup without one, but that just depends on whats comfortable for you.
My Tc4 did the same thing. It wants to spin out coming off the corner on power. Heres the changes i made that got rid of most of it for our asphalt...
Front shocks: Red AE spring, #1 piston, 50wt oil, inner hole on arm, #2 hole on tower (counting from the centerline of the car)
Rear shocks: Green AE spring, #1 piston, 40wt oil, outer hole on arm, #3 hole on tower (counting from the centerline of the car)
4 degree caster blocks (tried 6 degree blocks, too much caster)
Are you using any washers under the ballstuds on the steering rack? Im using a silver ballstud (+.030 over a black ballstud) and another .030 washer under each steering rack ballstud.
Which hole are you using on the steering knuckle? If youre using a front diff, use the inside hole on the steering knuckle... and be sure your steering turnbuckles are parallel with the lower control arm at static ride height. This is your bumpsteer adjustment, and varies with the caster blocks you use, suspension shim choice under the suspension mounts, and the number of washers under the steering knuckle ballstud.
If you can, try to crossweight the car on an MIP Tweak Station, or someones balance beam. The shaft cars are really sensitive to crossweight changes, or lack thereof. If your on power oversteer was mostly to the right, and not so much to the left... then this is something you need to look into. If you dont have threaded shock bodies for the fine adjustments, let me know... i have like 6 full sets of them, and youre more than welcome to one.
I also shortened the front camber link one hole, but we use grape soda on our track. That difference, and the X pattern tires you use for RCGT may not require that change. Also, make sure you are building your shocks with as little rebound as possible (AE's bleeder caps preferred), it will provide the best overall 'feel' for asphalt.
Quick pix:
This weekend, i am testing my theory that it is the Tc4 steering rack that causes the majority this 'off the corner, on throttle oversteer' problem and installing a Tc3 steering rack. I havent had a Tc3 rack in a Tc4 tub in many years, and that was on carpet... so we will see. If so, then the chassis can be tuned to go faster without this issue...
