Team Associated TC4
#8386
yea the original ones for me are a pain in the but to build.
#8387
The shock bladders are great. I bought them like 5 months ago and the only time i rebuilt them was when i had to change the oil weight. They are just as smooth as my tamiya shocks that i have to rebuild at least once a month. My suggestion is that instead of using foam between the bladder and cap, just make a small hole in the plastic shock end and dont put any foams. This factors out the need to match the rebound between shock pairs.
Eric-
Eric-
#8389
shocks
try 2 o rings underneath seems to work well ......
#8390
AE part# 31128 Lightened Steel Outdrive Diff Kit for FTTC4
I need two of these to replace the composite set I have now. The Plastic drives arent worth anything!!! I have changed out three sets already
If anyone knows where I can get two NIP sets...please let me know..
Jeff
Jeff
#8391
As you said before, the plastic outdrives are not worth anything. I upgraded to the lightened steel out drives from AE. The reason I chose the lightened steel over the aftermarket aluminum outdrives is the last longer and are a lot smoother. So yes the outdrives are a little heavier but the will last you a lot longer, and best of all will be a lot smoother.
RH
RH
#8393
Jeff
Jeff
#8395
"Apex" The only dealer that has the Delrin Outdrives that I know of in the states is Speed Tech RC. Check this link out, http://www.speedtechrc.com/store/ebp...id=339&id=1033 , this is the link fo the black delrin outdrives. I hope this helps. Oh an also check out the aftermarket section, there are alot of other cool hard to find that stuff that usually has to be ordered from overseas.
RH
RH
#8396
RH
RH
yea i run them and they are great, and really smooth, and if you run them all around around they give the car a more fluent roll, like it rolls further
#8397
Can anyone tell me that is the tc3 input shaft compatible with tc? i found the irs alu shaft but that for tc3
#8398
do associated make spool for tc-4? if they do can anyone please give me the part numbers, and picture. Thanks in advance
#8399
ok folks...
I am looking for AE part# 31128...I need two of them..
If anyone knows where I can get them besides AE...please let me know...
All the info so far has been great...but this is the part# I am looking for.
Thanks for everyone's help so far...you folks are awesome...
Jeff
Jeff
#8400
http://www2.towerhobbies.com/cgi-bin...?&I=LXJTS2&P=7
