Team Associated TC4
#6886
Will the fit the tc3, yes I have the tc3 still,and love it.
#6887
Weird shock Qweschun
I cant get the VCS bobbin to snap down into my shocks anymore. I have switched to the yok caps and am not using the VCS foam around the bobbin. Can I just use the flat piece used in the older AE shocks? (I am guessing the edges of the VCS bobbin have worn. This keeps the 2 o rings from compressing around the shaft at the bottom so my shock leaks like a sieve)
#6888
Set-up question
At 5mm ride height, what droop settings (measuring via: droop over ride height) are you guys using for 19t/Mod foam on carpet? First time running foam with this car and I need a starting point. Thanks -Dan
#6889
Wouldn't mind a link for these either.
31123 Shock kit and 31126 Battery Strap Kit
Got the new FT TC4 all assembled but to scared to run it at the moment cause I dont want to scratch it cause it looks so good.
#6890
cant you just put TRF shocks on the normal TC4 bushings?
#6891
Foams
Can anyone give some recommendations for some foams.
Running on a low grip ashpalt track, old netball courts.
Currently running ellingi 35/37.
#6893
Originally Posted by BlackKat
Set-up question
Try 5 front and 4 rear... its a good starting point.
- DaveW
#6894
Ran into a bit of trouble Dave. If I completely back out my front droop screws I can't achive anything more than 4mm over ride height (and this is with 60mm tires) Do I need to grind away from the chassis (I'm still running the tub) and lengthen my shocks or something?
#6896
Are you running the outer shock mounting holes on the arm... and out on the shock tower? If not, try taking the shock off of the car and pulling on the shaft... it sounds like the VCS bobbin is creeping up into the shock body, and limiting your total downtravel. In worse case, it backs out so far the o-rings pop loose and the shock drains the oil. If this is your problem, then the only way to solve it is to replace the bobbins, and insert them at an angle, each point in until you have to flatten the bobbin at the last point... if you just press it in straight all eight points on the bobbin get shaved a bit, and reduce the bobbins ability to stay in place. When i run the outer positions on the shock tower and the arms with smaller tires, i use ASC6419 .56 length unobtanium shock shafts. The standard shafts are shorter and can cause a problem with total downtravel... especially with smaller tire sizes. But if your running 60mm foams, it sounds like an internal issue. Check it out and let me know.
- DaveW
#6898
LOL Bob no the 5 and 4 are droop gauge numbers for his 60mm tires. Its a general starting point. As the tires get smaller so would the droop gauge numbers. I usually run similar amounts of droop as you mentioned, and actually measure droop with my ride height gauge, like i mentioned in e-mail before. Although i have found lately that the way my car is setup, it is seeming to like a little more droop than before. You would think with whiteF/yellowR springs and a mediumF/thinR anti-rollbar the car wouldnt roll alot. The FT is a different beast altogether. Im pushing for more track time this weekend.
- DaveW
- DaveW
#6899
hey Dave are you sure you aren't getting the "wheel barrell" effect from shocks being too stiff? PW used to talk about it all the time with the old Mi2. Just food for thought. I'm with ya on the track time. I should be getting my new motor mount this week for my car and then Im going to try to get some track time on Sunday...probably just practice but thats fine with me. If not then It will be first leg of the ORL series with no practice, and to top that off...the track that its at is cuffs, williams, shreff, home track. They said last week there was an A-E mains and you had to fight to make the A. Just like a National and this is going to be every week. How sick is that.
#6900
