Team Associated TC4
#6901
Originally Posted by DaveW
LOL Bob no the 5 and 4 are droop gauge numbers for his 60mm tires.
#6902
Close but no cigar...
The math would work out 1mm for every 2mm of tire wear. When you measure the tire diameter you are measuring both radii (axle to outer edge both ways) where as far as droop and/or ride height are concerned you are only dealing with one radius (axle to the bottom).
I just check and adjust my ride-height and corner weights (tweak) between rounds rather than measure my tire diameter, etc and do the math (easy though it may be) and fart with the down-stops. May be the lazy man's way out, but I never find the difference in droop over the course of two heats and a main are enough to bother with. I DO check and re-set prior to the next race.
Scottrik
Scottrik
#6903
rear toe question
FT TC4 setup according to foam setup sheet.
As I was adjusting front toe and camber all around on my hudy setup system I thought I would check the rear toe with the circle block and the X-3.0 block...
I measured -2.5 on the left and -1 on the right????? I double check everything and all is right. It is mirroed left to right. Anyone else check it and seen a difference? I expected it to not be exactly 3 but atleast close to the same left to right.
Pete
Pete
#6904
Originally Posted by BlackKat
How do I adjust my droop going by gauge numbers as the tires wear to keep the same setup? 1mm for every 1mm of tire wear?
- DaveW
#6905
Thanks. Would I be screwing the droop screws in for every 2mm of tire wear or out? LOL
Despite the fact that I've read a million different ways to describe how droop changes with tire wear I've never been able to understand the concept of how suspension travels more based on tire wear, I just do not understand it.
#6906
Couple questions
Finally got to run the car.Awesome.I'm running the foam setup WITHOUT the optional parts,(can't get them yet,next week).DBl pink/orange front,dbl pink rear.Brand new ozite carpet.5mm ride heaight all around.The car is very stable in the high speed chicane/s's,and hugs the rail in the high speed turns.Smooth and balanced.Now for the questions...1)when coming into the 180,letting off the throttle,I have a very bad push.Any slow speed turns the pushes like mad.2)The rear foams wore from 62mm to 58mm after 4 6minute runs.The fronts show hardly any wear.Any ideas to cure the low speed push?Any comments on the rear tire wear?I'm going tomorrow for some more testing and any ideas/comments would be very appreciated.Thanks,Mario.
#6907
I can't help with the pushing problem, but I would check my rear camber and rear toe to fix the rapid wear. Especially if you are getting uneven wear in the rear. I will mention also most foam racers dont start their foams that large. I belive foams wear more from 62 to 59 than from 59 and below. They find a sweet spot and wear better at a smaller diameter. This isn't from experience but from heresay.
#6908
andrew,I hear you on the start size.I've heard that also.Bein'cheap,figured I'd break them in with the practice.The thing that bothers me is the amount on the rear versus the front.I've heard that the fronts wear more than the rear normally.Just wondering if this is other peoples experience with this car.Thanks,Mario.Oh,The wear is even,just seems excessive to me.Camber and toe is good.
#6909
I know this sounds silly but are you sure you have the double pinks on the rear and the double pink/orange on the front? That kind of wear is not normal if you ask me. What about your tire rubbing on something besides the carpet, like the body? Just throwing ideas at you. What toe and camber are you running? Is there any way we can view your set up in its entirety?
#6910
Yes,dbl pink rear,dbl pink/orange front.Nothing rubbing,the setup is the foam standard setup that comes with the kit.The only differences is I used the stock parts instead of the optional ones.EX;the 2.5 istead of the 3.0 and the square instead of "O" in back.Going to practice again tonight,try out some ideas.Thanks,Mario.
#6913
By adjusting the droop screw (backing it out) to make up for the change in angle you'll maintain the same up (rebound) travel. If you don't adjust the droop at all with tire wear/ride height it'll reduce the up travel. With enough tire wear/ride height, eventually the droop screw may end up bottoming out against the chassis leaving you with no up travel.
Just remember to check and adjust for droop (up travel/rebound) whenever you adjust for ride height.
#6914
X 2.5 + square = 2.5 ° toe in
X 3.0 + "O" = 1° toe in
it could be the reason of your problem??
#6915
Originally Posted by Tigger
It's not based on tire wear alone. Think of it this way. As the tires wear down you need to raise the chassis (using shock collars) to maintain the chassis ride height. Whenever you do this you are changing the angle of the lower control arm relative to the chassis, because the droop screw controls this angle, that is what affects the droop.
height...correct?
If not...screw it. I'll just maintain a certain # over ride height....or take the stupid screws out of the arms
Fender:
The 3.0 block + the Circle block = 2 degrees rear toe
