Team Associated TC4
#7846
so i heard a belt car from the a team is on its way
#7847
TC3 to TC4 setup
OK, I just got my FT TC4 all put together. I put the box rubber setup on it and I will be racing it this week.
I have an awesome setup for my TC3 that works great at my local track. I wanted to know if there is any way to transfer that setup over to the FT TC4? Is there any kind of guide, or am I starting over when it comes to the setup?
Thanks for the help
YEkim
Thanks for the help
YEkim
#7848
Thanks for the help
YEkim
Thanks for the help
YEkim
#7849
mike if you took the setup off the little setup sheet book that has a diff a one way and a foam setup take the diff one i ran it this weekend and was awsome.
#7851
Yekim
#7852
TC3 setups do not work on TC4's. They are totally different cars. If you need a setup for foam tires on carpet search back a bit on this thread and you will find my setup. Don't try to run Dave's setup when you see it... He had a lot of other stuff done to the car that won't work unless you copied that too ( IE running front arms on the rear). Basic starting point should be 70/2/purple front 50/2/copper rear (its either copper or gold I don't remember....which ever one is closer to 25lb spring LOL) camber 3 holes in with 2 washers front and rear. I ran losi XXXS rear hubs as well. That gives you more tuning options for roll center. Also run the 3.0 block with the circle block to give the rear 2.0 deg of toe in the wide stance. If you run on super high bite then give Bakers setup a try
#7853
YEkim
#7854
Originally Posted by bummy
hey what is the strongest diff to use? i melted the standard one racing in mod class. 13*2 motor and it just gave way. so what is the best to use
#7856
Thanks for the input. I'm running stock rubber, any setup tips for that?
YEkim
YEkim
#7857
#7858
OK, I'll bite.
#7859
Anyone else tried this?
#7860
