Team Associated TC4
#7501
Tech Legend
Trader Rating: 51 (100%+)
I found that Associated diffs over the years work great and last longer than most. I know in my FT GT's I could go months without re-doing the diff. I think the lightweight steel diffs are a little smoother than my lightweight plastic diffs they make. My steel ones in my FT are very smooth. I ran the car 3 weekends now about 30 packs worth and still pretty nice. I bought it used so I'm not sure how much it was ran before that but still really nice overall.
koabich it is funny but it does seems like Associated has a smaller onroad team as this time than the offroad team. I could be wrong but it just seems like that. It would be nice to see more guys running but I give Associated credit for not sending guys to run the lower classes just to try to get higher results. Maybe they have something up their sleeves for 06.
#7502
Originally Posted by koabich
I have noticed that too, they have very, very few team drivers in stock and even less in mod. They are heavily out numbered at races. It does make a difference when one manufacture has 2 drivers and another has 20. And I think in the case with Associated, the 2 to 20 comment is not all that exaggerated!
it's ok i guess because they got barry baker! just like mugen racing, they got mike swauger and they count on him on worlds races. the team is not big and almost like a one man show. but they do have a very poisonous snake on their arsenal
#7503
One of the big things that will save time is to precompress the diff spring. Get a good set of pliers and compress the spring several times. Once the diff is set there is no readjusting needed.
Walter
Walter
#7506
Thank you - are people using other brands other than associated? I assume the AE FT Drivers are using the AE springs and using their setups and when they call for Green, Silver, Blue springs etc. they are AE's.
K
K
#7508
GP3700s
GP3700s: Do they fit the original tub chassis properly, or is it just me?
#7509
I use Schumacher springs, without any problems, settings in lbs and provide some alternative values to the AE springs
Paul
Paul
#7510
I am having difficulty getting a bearing in a steel outdrive. Does anybody have a tip on how to get it in without damaging it.
#7511
I think the bearings are the wrong inside diamater....
#7512
What is the size of the bering that is used in the steel outdrive? is it 4x8x2 or 4x8x3?
#7513
Super Moderator
#7515
