Team Associated TC4
#3721
Speedway outdrives
Is there a web site where you can see their products, in english if possible
THX!!
THX!!
#3722
dave, have you tried the AE lightened steel ones? whats the weight like compared to the PAL ones?
im trying to get rid of weight where ever possible
#3723
What's wrong with IRS. It's alluminium and it's made in USA.
We use IRS spool up front and IRS alloy diff outdrives on the rear.
Never had any trouble with either.
I don't like IRS pin cushions, in fact I use Corally Assassin drive shafts with their own blades. They are a virtually straight fit.
Have a look at the attached pic.
#3724
Here's an even better pic of them on the TC3.
#3725
Originally posted by johnbull
In fact I use Corally Assassin drive shafts with their own blades. They are a virtually straight fit.
Hey John,
Where do you think I could find those blades here in the States?
Thanks!
#3726
Originally posted by Jack Smash
Mot guys are running around a 6.10:1 ratio with Reedy 19turns around here. That would be a 100 tooth spur and a 41 tooth pinion. You might also want to get a few smaller pinions to accomodate for smaller tracks and different driving styles. Kimbrough and PRS make good spurs and PRS would be the only pinions I would buy right now. I can't get any other pinion as quiet as I can the PRS.
#3727
Precision Racing Systems
You might want to go with something smaller than a 100. Some of the guys were questioning if a 41 tooth pinion would fit.
Maybe try 94/ 38 and a couple smaller pinions and you would be ok.
#3728
what kinda gearing wold you guys suggest for a large outdoor track with a 12t on rubbers?
in the xray i used to run about 6ish but theres noway i can get a 30/72 in the tc4(that would give me about 6 iirc)
#3729
#3730
If I could use my existing dogbones I would use them. Those Delrin ones are still lighter than aluminum.
#3731
and to be honest, like 80% of the time i run stock anyway (at the time i got steel ones, i ran mod)
so strength of the delrin ones compared to the stock isnt a problem (i found stock outdrives to be strong enough for 27t motors)
its just that its a right pain having your dogbones popout with the stock outdrives....just trying to find an alternative to the steel ones...that is much lighter (my tc4 weighs 1600 with the fan kit and steel outdrives ) and dont let your dogbones popout during races.
i think im going to give the delrin ones a shot in the near future.
#3732
I was popping the right dogbone almost every weekend and I was running stock. Now I run the steel one up front. Its not the static weight of the steel outdrives its the rotating mass that sucks the most. I was going to do the irs ones but my LHS didnt have all the parts to do the conversion.
#3733
I am currently building my TC4 and bought the lite weight steel one for the rear with a one-way up front. I saw the plastic diffs in the kit and after melting one down in my TC3 the gear and snapping the outdrive I did not want to have that problem in my TC4. I only run a C2 in my TC3. Also had a racer do the same with his TC4 although he had a lower turn motor in his. Should I run the same gearing with the 4 that I am currently running in my TC3 I know the drive ratio is the same. Currently running a 72/28 in my TC3 and it gets a bit warm. Waiting on my kinetix C2 and will be putting the GTX in my TC4. Thanks Gene
#3734
The tc4 uses the same ratio as the 3 2.5 so you are all good.
#3735
1)weight the PAL one is lighter by 1~2grams
2)does not need separate T-nut to build the diff
3)the PAL diff can be shimmedmore than the IRS diff for better gear mesh
4)it comes with very strong teflon blades that are larger in size compared to the corraly ones
5)2 colors Black and Blue
-Dave
